2 cycle oil - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by millhouse76, this thread has received 7 replies and been viewed 1016 times.
post #1 of 8 (permalink) Old 03-29-2008, 08:01 PM Thread Starter
2 cycle oil
I just read a post that mentioned 2 cycle oil being added to the tank.
I normally put in half a bottle of diesel klean on evey fill up. Can anyone tell me the benifits of running 2 cycle oil?
Thanks
Ryan
millhouse76 is offline
post #2 of 8 (permalink) Old 03-29-2008, 09:55 PM
2 stroke oil
All the benefits are listed elsewhere in this forum. I have a 1997 F350 with 780,000 certified miles on it . Last year I noticed a power loss and an annoying increase in engine noise. Saw an article about the use of 2 cycle oil and have been using it ever since. My engine is much quieter and my power is back. The truck is completely stock. Just my experience.
ralfran is offline
post #3 of 8 (permalink) Old 03-29-2008, 10:36 PM
TDG Mafia #95
bluovaltruk01's Avatar
2 stoke oil has a few benefits due to one reason. Lubrication. The ULSD fuel that we are running now doesn't have anywhere near the lubricity of the LSD. This causes increased injector noise, lower mileage, and added wear on your fuel system. The 2 stroke adds some lubricity, and since 2 stroke is designed to be burned, its harmless. It mixes very well with diesel fuel, and helps counteract these problems. If you decide to try it, make sure its ashless 2 stroke oil (TCW-3(I use super-tech brand outboard 2 stroke oil from walmart)) and mix in 1 oz per gallon of fuel.
bluovaltruk01 is offline
post #4 of 8 (permalink) Old 03-30-2008, 04:48 AM
two stroke oil adds lube, is cheap and is ment to be burnt.
crazycracker is offline
post #5 of 8 (permalink) Old 03-30-2008, 05:05 AM
I gained about a mile per gallon...not to bad...and It brings "GOOD Thoughts" to my mind about all that extra lube!!!
deertrax4430 is offline
post #6 of 8 (permalink) Old 04-16-2008, 03:37 PM
2nd Gen Guru
Mopar1973Man's Avatar
Here is my 2 cycle oil page...
http://mopar.mopar1973man.com/2002%2..._cycle_oil.htm
Mopar1973Man is offline
post #7 of 8 (permalink) Old 04-16-2008, 03:49 PM
ive ran all sorts of fuel additive through my truck but then i tried the 2 cycle oil and man what a difference it made!!! ive been using it since and my father runs it in his truck, dump truck, and all his heavy construction equipment. youll be glad u used it!!!
'94 powerstroke, 4x4, 5spd, 3" bullydog downpipe, 4" magnaflow ss downpipe back exhaust, AFE Stage 2 intake, autometer pyro, boost, & diff gauges, amsiol fully synthetic... and I'm just gettin started!!!
http://community.webshots.com/album/563051484TytFKK
turboculosis is offline
post #8 of 8 (permalink) Old 04-16-2008, 04:49 PM
i run a qt to every tank full in mine, noticeably quieter and smoother. i told a guy here to do it to his dodge and he had the same results.
