which o-ring is this? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bluovaltruk01, this thread has received 8 replies and been viewed 907 times.
post #1 of 9 (permalink) Old 04-07-2008, 10:06 PM Thread Starter
TDG Mafia #95
bluovaltruk01's Avatar
Found out I got ANOTHER damned leak. Which o-ring is this so I can replace it?
bluovaltruk01 is offline
post #2 of 9 (permalink) Old 04-08-2008, 12:40 AM
member
dont know but aint that were you shim the fuel pressure? I just got done replacing the drain valve orings on mine last weekend, I hate leaks
99stroke is offline
post #3 of 9 (permalink) Old 04-08-2008, 12:55 AM Thread Starter
TDG Mafia #95
It sure is. But I cant find the o-ring that goes there. It doesn't really look like an o-ring, but rather a bushing thats made of rubber. I'm not sure how long its been leaking but it really sucks.
post #4 of 9 (permalink) Old 04-08-2008, 01:33 AM
Which part is that? What's the component called....I can't seem to get my bearing?
_____________________________________
1996 F250 Supercab Longbed White with 168,000 miles. Gooseneck, Prodigy Brake controller, Diprocol guages/pillarpod,overhead guages, 3 in downpipe, 18K mod from Dfuser, DIY intake.
Burner718 is offline
post #5 of 9 (permalink) Old 04-08-2008, 01:36 AM Thread Starter
TDG Mafia #95
Its on the fuel pressure regulator, just to the right of the fuel bowl.
post #6 of 9 (permalink) Old 04-08-2008, 04:05 AM
MAFIA MEMBER 106
camojeeper's Avatar
it just fuel rubber for the return line you can get it at ford 15 min fix
STEVE TDG MAFIA#106
camojeeper is offline
post #7 of 9 (permalink) Old 04-08-2008, 05:11 AM
plainredtruck's Avatar
Images: 11
Isn't that called a "vibra-lok" fitting?
Maybe not, but sounds familiar.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #8 of 9 (permalink) Old 04-08-2008, 05:45 AM
Diesel Mafia #67
blackcloudCTD95's Avatar
There the same o-rings as the ones on the head. IM NOT SURE but I think there the same ones that go on the HPO lines.. NOT SURE THO...
Jordan
blackcloudCTD95 is offline
post #9 of 9 (permalink) Old 04-08-2008, 03:12 PM
MAFIA MEMBER 106
camojeeper's Avatar
no the rubber is like 1/4" thick its not really an o-ring more like a thick rubber washer hey blueoveltrk you can wrap some teflon tape on the nut side of the rubber it will buy you some time but is just a band aid
steve
STEVE TDG MAFIA#106
