1.0 turbo housing sound? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TSGS69400, this thread has received 16 replies and been viewed 2484 times.
post #1 of 17 (permalink) Old 04-11-2008, 12:37 AM Thread Starter
git-r-done
TSGS69400's Avatar
How will the exhaust sound of a 1.0 turbo housing change my exhaust. Will it whistle more or less. Will it be quieter or louder? I am curious. I have DIY intake, 3'' dp 4'' exhaust, and DP tuner with gauges. I want more wistle honestly. Mabey I should have left the muffler off.
Thad Seybert
2008 F-350 crew cab short bed Lariat 4x4 6.4 with 3.73's Spartan flash update 250 210 175 150, S&B intake, MBRP cool duals, Rockford amps, Infinity speakers, Tuff Tonneau,
1996 F-250 extended cab short bed 4x4 7.3 5-spd with 3.55's , DIY STG 1's, 4" Diamond Eye duals, DIY Intake, dp tuner, Cobalt gauges, Adrenaline pump, SD springs, D66 turbo, 6.0 intercooler, Custom electric regulated fuel system, Truetrac.
TSGS69400 is offline
post #2 of 17 (permalink) Old 04-11-2008, 12:48 AM
racehauler told me it will be a little more louder but idk bout the whistle...
cumminsdieselfreak is offline
post #3 of 17 (permalink) Old 04-11-2008, 01:03 AM Thread Starter
git-r-done
TSGS69400's Avatar
cool, thats what i want to hear, no punn intended.
Thad Seybert
post #4 of 17 (permalink) Old 04-11-2008, 02:13 AM
when I put my 1.0 housing on it made it a little bit louder. didnt really notice a difference in whistle.
97STROKER_08 is offline
post #5 of 17 (permalink) Old 04-11-2008, 01:22 PM
sweet thats some good news seems im puttin one on soon!
'94 powerstroke, 4x4, 5spd, 3" bullydog downpipe, 4" magnaflow ss downpipe back exhaust, AFE Stage 2 intake, autometer pyro, boost, & diff gauges, amsiol fully synthetic... and I'm just gettin started!!!
http://community.webshots.com/album/563051484TytFKK
turboculosis is offline
post #6 of 17 (permalink) Old 04-11-2008, 07:27 PM Thread Starter
git-r-done
TSGS69400's Avatar
me too. SWEEET
Thad Seybert
post #7 of 17 (permalink) Old 04-11-2008, 07:39 PM
I didn't notice a whole heck of a lot of noise level change. The exhaust tone may change slightly as it does any time you change something related to the exhaust system.
There may be an increase in the whistle you hear cruising down the road but that's mainly due to the boost being a little higher at the same RPM. If you run down the road at 5 psi boost now and change to the 1.0 you may go to 7 or 8 psi cruising.
Don't expect a turbine housing change to make a huge difference in the overall noise level of anything. It may change a couple of things slightly though.
Eric
Dually Club Member #53
racehauler is offline
post #8 of 17 (permalink) Old 04-12-2008, 06:47 AM
MAFIA MEMBER 106
camojeeper's Avatar
so is that why my brothers obs truck go'es down the road @ 75 making 5 lbs and my sd make 9 lbs its because of the turbine ex housing?
STEVE TDG MAFIA#106
camojeeper is offline
post #9 of 17 (permalink) Old 04-12-2008, 10:35 PM Thread Starter
git-r-done
TSGS69400's Avatar
yeah,, What is the size of the turbo housing on the SD's anyway?
Thad Seybert
post #10 of 17 (permalink) Old 04-12-2008, 10:53 PM
MAFIA MEMBER 106
camojeeper's Avatar
.84 for 99.5-03 the early 99 had the obs turbo intercooled with a wastgate and i belive the 1.15 ex housing IIRC
steve
STEVE TDG MAFIA#106
