Need some help with some codes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Eagle One, this thread has received 4 replies and been viewed 2377 times.
post #1 of 5 (permalink) Old 01-18-2009, 08:08 PM Thread Starter
I have a 2000 Ford F-250 with a 7.3 Diesel. My service engine light soon came on and the codes showing up on my reader is P1280 the ICP sensor out of range low and PO475 Exhaust Pressure Regulator error. The truck is definetely running differently but not bad. My question is are these very hard sensors to change out do you need any special tools and are these items under any pressure that has to be relieved from the system where are they located? My manual doesn't show the ICP sensor and for the Exhaust pressure Regulator doesn't show that one very well either.
Two other questions could the ICP sensor trigger the Exhaust code and on another note instead of this exhaust regulator could the exhaust regulator sensor trigger the PO475 code?
Any help with information would cetainly be appreciated by me. I don't have the money to take it in to the dealer so I have to make the repairs my self and I don't want to make a serious mistake..
Thanks from Eagle One.
Eagle One is offline
post #2 of 5 (permalink) Old 01-18-2009, 10:55 PM
The P1280 is a common code with injectors that demand alot of oil.It is telling you that they are useing more oil that the HPOP can give them.PO475 not sure but on my 97 it is the tube to the sencer is pluged or the sencer is bad.
1997 F250 XLT cc PSD 4.10LS E4OD(AB code Cali truck)255K
18k mod
3" down pipe
No cat
Diy intake
egt,trans,boost,oil temp,water temp,oil pressure,volt
2" leveling
Sonnax Valve/Springs
1996 F250 XLT EC PSD 4.10LS E4OD (AB Cali Truck)135K
Diy Intake
DB Exhaust Brake
ono_55 is offline
The Following User Says Thank You to ono_55 For this addition to TDG:
Eagle One (01-18-2009)
post #3 of 5 (permalink) Old 01-19-2009, 01:21 AM
You can't have any!
mech2161's Avatar
The 1280 is ICP circuit out of range. open/grounded circuit, biased sensor, pcm
It's not the same as a 1211 that indicates low ICP pressure.
0475 is Exhaust pressure control valve malfunction. open/grounded circuit, solenoid open/shorted, failed pcm
I think you need to start looking for some bad wiring.
Kevin
SLEDPULLMOTORSPORTS
12v CONVERSION FOR SALE
South Bend Clutch, MOTORSPORTSSUPPLY.COM
Carson Stauffer Diesel Service
Pure Diesel Power
Weston Shupe
zstroken
mech2161 is offline
post #4 of 5 (permalink) Old 01-20-2009, 06:13 PM Thread Starter
Thanks for the information but i can't seem to locate the ICP sensor? My manual doesn't seem to have it listed or where it is at?
post #5 of 5 (permalink) Old 01-20-2009, 06:30 PM
MAFIA MEMBER 106
camojeeper's Avatar
drive side valve cover near the front of the motor on top it has a 3 wire plug it should be sticking up in between the v/c and the fuel bowl
STEVE TDG MAFIA#106
camojeeper is offline
The Following User Says Thank You to camojeeper For this addition to TDG:
Eagle One (01-22-2009)
CEL codes....Why? UNDER PRESSURE 1994-2003 7.3L Power Stroke 13 01-11-2008 07:09 AM
Codes 02sprtcumns 5.9L Cummins (1998.5-2002) 3 01-01-2008 05:43 PM
codes ??? imported_Tommeyboy 5.9L Cummins (2003-2007.5) 5 07-03-2007 02:43 AM
What do these codes mean??? WBV06CTD 5.9L Cummins (1998.5-2002) 7 12-06-2006 03:49 AM
Need help with codes! imported_Honda30 2003-2007 6.0L Power Stroke 7 11-08-2006 12:41 AM
