wait to start engine light - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dieselal, this thread has received 9 replies and been viewed 3705 times.
post #1 of 10 (permalink) Old 06-01-2009, 09:58 PM Thread Starter
Before I give myself vertigo crawling under the dash has anyone had the wait to start engine light go out? I can hear my solonoid sp? clicking so that is ok. I just turn the key and wait a little bit but would like the light to work. Thanks for any help.
Al Weiss
dieselal is offline
post #2 of 10 (permalink) Old 06-02-2009, 12:52 PM
Yoslick's Avatar
I believe that whole 4 light cluster, wait to start, water in fuel etc... is considered 1 module and has to be replaced, you can't just change 1 bulb....
DCC(SW/MTS) USN-Ret 75-95
96 F-250 4x4 7.3 73k
3" DP
Gutless Kitty
DIY Air filter (NAPA 6637)
3 Gage Pod
14.6k Mod
Yoslick is offline
post #3 of 10 (permalink) Old 06-02-2009, 05:24 PM
TDG MAFIA MEMBER #77
TooLoudTooBad's Avatar
Thats how it was in my 96. You had to change out the cluster and its not cheap if I remember right.
TooLoudTooBad is offline
post #4 of 10 (permalink) Old 06-02-2009, 11:30 PM Thread Starter
wait to start light
Too Loud, Got botom bezel off but can't get top bezel lto come fully loose. Just enough room to wedge my hand in there. Am I missing some screws or something? It seems to be fastened or stuck around the steering column.
Thanks
Al Weiss
dieselal is offline
post #5 of 10 (permalink) Old 06-03-2009, 07:26 PM
Not sure. I had the truck in for some other service and had the dealership do the dash lights as well. Sorry man...
post #6 of 10 (permalink) Old 06-05-2009, 03:07 AM
ccp
THE MASTER OF DISASTER
ccp's Avatar
Send a message via AIM to ccp
did you check the idm fuse? that can make that light not come on before you go rippin into the dash make sure the fuel bowl heater isnt shorting out i had this problem and the WTS light doesnt come on but everything else did.
99.5 F-250 7.3 4X4 reg cab.
custom intake
dp tuner
suncoast/DTT Frankentrans
and a whole bunch of other crap i dont really need.
www.cabincreekpaintball.com
ccp is offline
post #7 of 10 (permalink) Old 06-05-2009, 03:21 PM Thread Starter
wait to start light
ccp: The light came back on for a day or so but now is off again. The other items in that cluster show when I turn the key on. Maybe it is what you mentioned. What is the idm fuse and where is it?
Thanks
Al Weiss
dieselal is offline
post #8 of 10 (permalink) Old 06-05-2009, 09:11 PM
Thanks
Al Weiss
Fuse #22 (mega 30 A) underhood
STROKER#1 is offline
post #9 of 10 (permalink) Old 06-07-2009, 10:50 PM
Images: 3
If that IDM fuse blew, the truck wouldn't run.
and, I think you CAN change the bulb in the cluster. I thought I saw turn-out light plugs on it. Even if, its worth ripping into it, cause you gotta buy a new one anyway.
1995 F-250HD XLT. 7.3L, E4OD. TW 6 Position chip, K&N Intake--Tymar 3x4" DP--5" straight piped--36"x5" Miter Stacks--Rebuilt Trans--Trans-Go Tugger--Turbo Timer--Autometer Pyro, Trans, Boost guages in A-pillar--Cervini's Cowl Hood--Buckstop Bumper, and LOTS MORE!
Dana 60 Swap STILL in progress...
2003 Ford Mustang Cobra, Gotta love being blown!
1993 Ford Lightning, My 393ci Sleeper
weareweird69 is offline
post #10 of 10 (permalink) Old 06-07-2009, 10:53 PM
Images: 3
Thanks
Al Weiss
Use an Awl to remove the headlight knob, there is a little metal catch in there, it digs into the headlight switch rod holding the knob on.
There is a screw there, behind the trim bezel and they just pop out, use a small screwdriver, but wrap it in a rag so you dont mark your dash for pete's sake, and same on the other side of the column. They are 8mm I believe. Remove those, and gently pull the instrument cluster bezel out. Place your truck in 1st gear, if its auto, and set the E-brake and gently work the bezel out, and unplug the Fuel Selector Switch, and the Gauge Panel.
wait to start light england 5.9L Cummins 12 Valve (1994-1998.5) 2 05-03-2009 05:21 AM
No wait to start light. woodman44 1994-2003 7.3L Power Stroke 4 11-28-2007 08:36 PM
Wait to Start Light MOOSE 04 5.9L Cummins (1998.5-2002) 6 11-28-2006 12:01 AM
00' F350 No Start, No Wait to Start Light or SES light Huckster 1994-2003 7.3L Power Stroke 8 10-27-2006 08:38 PM
Wait to start light question jeffro22 2003-2007 6.0L Power Stroke 14 06-12-2006 10:28 PM
