Bad Idle and Hard Starting... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by medarocket, this thread has received 2 replies and been viewed 947 times.
post #1 of 3 (permalink) Old 06-02-2009, 12:22 AM Thread Starter
Unhappy Bad Idle and Hard Starting...
Ive had the truck for a month and originally everything was perfect. Start right up after glow plug light and running smooth and perfect... Now hard starting and will start easier if I hit the gas a bit. 2 Brand new batteries, get it going faster and faster seems like it is starving for fuel. Once it gets started it it has a rough idle, shakes the whole truck but only on an idle. You get the truck off and idle and its fine... I did replace the fuel filter and what brings me here is my lack of experience knowing why i am air out of the valve at the top of the fuel filter housing. I imagined that i needed to bleed it and did more than i thought could have been in there. I had the problem previous to the filter coming off and now it remains. I didn't want to start throwing money at what could be 6 different problems and didn't see anyone with the same exact symptoms. Thanks
medarocket is offline
post #2 of 3 (permalink) Old 06-02-2009, 01:00 PM
Yoslick's Avatar
If I understand you, your saying air is accumulating in the fuel filter? sounds like you either lost a pick up tube in your fuel tank (do you have 2 tanks and does it do it with both) or your lines from your fuel selector valve have a hole in it some where and your sucking air.. Theres also a little screen filter down inside the fuel bowl you may wanna check and clean with a q-tip..
DCC(SW/MTS) USN-Ret 75-95
96 F-250 4x4 7.3 73k
3" DP
Gutless Kitty
DIY Air filter (NAPA 6637)
3 Gage Pod
14.6k Mod
Yoslick is offline
The Following User Says Thank You to Yoslick For this addition to TDG:
medarocket (06-03-2009)
post #3 of 3 (permalink) Old 06-03-2009, 10:36 PM Thread Starter
I have 2 tanks and it has a problem with both tanks... I believe it is in the fuel line it just never leaks fuel. I put a line off the bleeder on top of the fuel filter housing yesterday and blead off air and fuel continually into a jug and it ran like a top and could shut off and it would start up without skipping a beat. No idle problem either. Am i right that it is the fuel line that is leaking between the junction of the fuel line block from both tanks to the fuel filter housing? Where do i get that line?
Hard starting.... crazycracker 7.3L and 6.9 IDI (Pre 1994) 8 01-10-2008 08:21 AM
hard starting rough idle blue smoke 87_f250 7.3L and 6.9 IDI (Pre 1994) 11 01-21-2007 03:02 PM
hard starting pork99 5.9L Cummins (1998.5-2002) 4 09-06-2006 12:24 AM
hard starting and not starting fender 5.9L Cummins (2003-2007.5) 2 01-07-2006 07:27 AM
Hard Starting!!!!!!! lilshmo 1994-2003 7.3L Power Stroke 10 01-06-2006 01:58 PM
