Help, oil in coolant reservoir !! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by eng55marine, this thread has received 3 replies and been viewed 5821 times.
post #1 of 4 (permalink) Old 06-02-2009, 12:45 AM Thread Starter
I was driving home from work and noticed the oil in the reservoir , about two inches. I noticed the leaking oil on the ground when i got home, opened the hood and found it leaking out of where the engine coolant goes. Any suggestions would greatly be appreciated.
Sorry, I have 2001 7.3L SD, with 110,000 mile on it.
eng55marine is offline
post #2 of 4 (permalink) Old 06-02-2009, 12:57 PM
Yoslick's Avatar
I'd start at the oil cooler by the oil filter and work your way towards the injector cups..... good luck.
DCC(SW/MTS) USN-Ret 75-95
96 F-250 4x4 7.3 73k
3" DP
Gutless Kitty
DIY Air filter (NAPA 6637)
3 Gage Pod
14.6k Mod
Yoslick is offline
The Following User Says Thank You to Yoslick For this addition to TDG:
eng55marine (06-02-2009)
post #3 of 4 (permalink) Old 06-02-2009, 06:31 PM Thread Starter
Thanks, any one have the information on how to replace the oil cooler or to test it to see if that is where the oil is leaking.
post #4 of 4 (permalink) Old 06-03-2009, 01:29 AM
beware the dark side
it is easy to replace. I have replaced the orings and seals in a couple cuz they were leaking. It is located on the drivers side of the block and has 5 or six bolts holding it onto the block. Remove the bolts and it will come right out. You will prob have to get a new one from ford if that is the prob cuz i have not heard of anyone making one aftermarket.
2003 F-350 XLT 7.3L 4X4 Crew Cab, 3.73, Custom built 4R100, AFE intake, Turbonetics BB Turbo W/1.0 A/R exhaust housing, 238/100% Hybrids from Jim @ Rosewood, 5 inch exhaust w/ 6 inch stacks, Tuned my Matt @ Gearhead, Autometer colbalt gauges, Custom built traction bars, viair dual compressor onboard air system. Mickey Thompson Classic II Rims with 315/75R16 BF Mud Terrains, and 4 inch Rough Country lift kit
New Truck: 2000 F-450 XL 7.3L Standard Cab, 6 Speed Stock for now
Trailers: 1999 Jayco 30' 5th wheel
2004 Wells Cargo 20' enclosed trailer (portable shop)
Its not how fast you get there but how much you can pull on the way there.
vader's fury is offline
The Following User Says Thank You to vader's fury For this addition to TDG:
eng55marine (06-03-2009)
fuel coolant reservoir question deebarjay 2008-2010 6.4L Power Stroke 6 06-10-2009 04:13 AM
New coolant reservoir mschwing82 2008-2010 6.4L Power Stroke 17 03-16-2009 03:38 PM
Windshield Reservoir Robts 2003-2007 6.0L Power Stroke 3 03-18-2008 01:26 AM
reservoir shocks? chvylac General Ford Truck and Excursion 19 06-16-2007 10:42 AM
HPOP Reservoir leak rescueu 1994-2003 7.3L Power Stroke 1 05-04-2007 12:10 PM
