Anti-lock brake light - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lord_Zarkon, this thread has received 7 replies and been viewed 1581 times.
post #1 of 8 (permalink) Old 06-03-2009, 05:17 AM Thread Starter
Any idea how to troubleshoot this idiot light problem? Does it throw a code that can be read?
Lord_Zarkon is offline
post #2 of 8 (permalink) Old 06-03-2009, 12:25 PM
Yes, it throws a code that can be read. A normal hand-held programmer cannot read this code, and neither will a generic OBD-II scanner that you find at the auto parts store. Something like Autoenginuity or Snap-On scanner, or taking it to a dealer/repair shop can pull the code.
I had the ABS light pop up on my truck once. It told me there was a problem with the front driver's side ABS sensor. Jacked up the truck and found that the hub bearings were toast and it took out the sensor with it. So it wasn't really an ABS problem, but rather a wheel bearing issue.
Pocket is offline
The Following User Says Thank You to Pocket For this addition to TDG:
Lord_Zarkon (06-05-2009)
post #3 of 8 (permalink) Old 06-04-2009, 03:08 PM
Cratos's Avatar
is your speedo acting up to? it could be the sensor on the rear end
Cratos is offline
The Following User Says Thank You to Cratos For this addition to TDG:
post #4 of 8 (permalink) Old 06-05-2009, 03:04 AM
ccp
THE MASTER OF DISASTER
ccp's Avatar
Send a message via AIM to ccp
it comes on if youre low on brake fluid also im sure theres a million things but thats pretty easy to look at and check.
99.5 F-250 7.3 4X4 reg cab.
custom intake
dp tuner
suncoast/DTT Frankentrans
and a whole bunch of other crap i dont really need.
www.cabincreekpaintball.com
ccp is offline
The Following User Says Thank You to ccp For this addition to TDG:
post #5 of 8 (permalink) Old 06-05-2009, 03:18 AM
the haynes manual for the obs truck tells of a process to go through that gives you a blink code you can troubleshoot.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. BDP modded IDM. Heim joint clutch linkage. Adrenaline HPOP. LUK SMFW. DIY Elec. Fuel. FS1282, FF5230 fuel filters.
sdan27 is offline
post #6 of 8 (permalink) Old 06-05-2009, 04:17 AM
pontiacross's Avatar
easy to fix
-step one remove dash
-step two remove bulb
-step three reinstall dash
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #7 of 8 (permalink) Old 06-05-2009, 06:01 AM Thread Starter
Hmmm, interesting variety of replies. No speedo problems (truck speedo, mine is too tight), no issue with low brake fluid..... it's been a year since I had the front end checked out, it may be something there. I'll see if the local shop has a proper code reader and go from there. Many thanks !!!
post #8 of 8 (permalink) Old 06-05-2009, 09:05 PM
KEE KEE WHOO!
sotexy's Avatar
Send a message via AIM to sotexy
also my 2 cents.
low brake fluid dose cause this from my experiance in other ride
TDG LUSH ELITE #1
TDG Singles Member #148
TDG Outlaw #29
TDG AMERICAN #3
TDG B.O.M.B Squad #3
TDG Ridin Dirty #13
"Lose the zero, get with a Hero!"
"PUT SOME SOUTH IN YOUR MOUTH!!"
sotexy is offline
Tourque Converter Lock Up Light cumminsdiesel 12 Valve Performance 19 01-06-2010 04:17 PM
Anti-lock breaks!!!=[ farmboyford07 General Ford Truck and Excursion 5 12-29-2007 06:16 AM
E-Brake Light Steve McQueen 1994-2003 7.3L Power Stroke 4 02-25-2007 08:46 AM
Help...Installed chip now anti-theft light flashing Blown306 1994-2003 7.3L Chips & Tuners Forum 7 02-15-2007 01:58 AM
Brake Light fuzzys69 General Ford Truck and Excursion 3 04-02-2006 03:02 AM
