Leveling Kit - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by redbaronmx319, this thread has received 19 replies and been viewed 2488 times.
post #1 of 20 (permalink) Old 06-05-2009, 10:34 PM Thread Starter
Leveling Kit
So I have this buddy of mine who has this guy do all of his lifts on his truck and I talked to the guy and he said he could do a leveling kit for me installed at $300 He said he is going to weld his own blocks at whatever height I want(Which will probly be 2 inch) insted of adding leaves. Do you guys think it is worth it or should i just buy the leaves and u bolts and do it myself??? Whatever will be cheapest and RIGHT is what ill do...
redbaronmx319 is offline
post #2 of 20 (permalink) Old 06-05-2009, 11:57 PM
tasman650's Avatar
leaves and ubolt is the safe way to go
2005 F350 CC SB Harley Davidson Edition Blue, 4" Turbo Back Straight Pipe to Duels, SCT with Innovative Tunes, ARP Headstuds, EGR Delete, 20" ION Rims, 2.5" Cage Leveling Kit, 30,000k HIDS, Blacked Out Markerlights, Sidemarkers and Taillights
tasman650 is offline
post #3 of 20 (permalink) Old 06-06-2009, 02:01 AM
Riding solow on the Hog
Sleeperstroke's Avatar
Any talk of blocking the front is dangerous and stupid. DO NOT BLOCK YOUR FRONT AXLE, PERIOD. Its DANGEROUS. And STUPID.
"Mini" Spring packs are also a no no in my book. go with either a shackle lift, or AALs(WILL make your front end more "Jarring") or new aftermarket spring packs. Do it SAFE, do it CORRECTLY, and live to tell the tale. And tell your "Buddy" And his "Guy" That I said they are morons, unworthy of even being called hillbillies.
HeBLEEPll, I dont even like my back end having STOCK blocks....
Nuff said, drive through.
"MOby" The big white bio-burning 03 7.3 4x4. 6637, straight piped stock exhaust, and a new "secret" blend of Haul asBLEEPsing mods and upgrades. Suffice to say, its still not the fastest, but its quick enough to worry lots!
Sleeperstroke is offline
post #4 of 20 (permalink) Old 06-06-2009, 02:08 AM
brendonv's Avatar
I went with the shackle lift, for ease of installation, no "block", cheap, no alignment needed. Raised about 1.5" for $70. All's good so far.
Early 1999 F350 DRW Dump, 6spd 4x4, 4" Turbo Back and DIY Intake
Early 1999 F350 SRW 8' Box, 6spd 4x4 Stock
brendonv is offline
post #5 of 20 (permalink) Old 06-06-2009, 02:50 AM
BillsFan's Avatar
Add a leaf $128.95.
http://www.suspensionconnection.com/...con/82111.html
Blocks and shackles = trouble.
and Bob @ DieselSite!
TDG Singles Club Member #73
Ridin' Dirty #64
BillsFan is offline
post #6 of 20 (permalink) Old 06-06-2009, 03:25 PM
Well, this stupid moron went with the mini spring packs. I put them on two years ago. After install there was absolutely no change in ride or the way it drives. It is a two inch lift.
D-Man is offline
post #7 of 20 (permalink) Old 06-06-2009, 04:46 PM
dzljon's Avatar
blocks are alright in some cases bit stacking blocks or using huge blocks is not a good choice, add-a-leafs are good, the spring pack leveling kits give you lift but make the truck ride really realy realy stiff, i just removed them from my truck and installed a Icon hangar and shackle kit. IMO if you just want a little bit of lift the hangar and shackle kit is the way to go, it will cost more money though.
99.5 F250, VGT 5.9 CR cummins
dzljon is offline
post #8 of 20 (permalink) Old 06-06-2009, 05:19 PM Thread Starter
Originally Posted by BillsFan View Post
Add a leaf $128.95.
Alright, but dont i need to add 2 leaves or 2.5 inches to the front to be level? and then ill need new u bolts so it should prolly be around 300 but idk...Iv been lookin around and this BOTTS truck place said theyll give me all brand new leaves for 250. JUST looking for as many options as possible.
THANKS for everyones oppinions
Whoever started this site was genious
post #9 of 20 (permalink) Old 06-06-2009, 09:05 PM
BillsFan's Avatar
I added that kit, you can use the existing u bolts. I know some people say not to, but i haven't had any problems. Just torque them and then check them after about 500 miles and retorque. The kit lifted the front of my truck between 1.5" and 2". It is just a hair under level but much better than it was. No difference in ride that I can tell. Hell, it's a 1 ton, what's it supposed to ride like?
There are many options. You just have to pick what you feel comfortable with.
Ridin' Dirty #64
BillsFan is offline
post #10 of 20 (permalink) Old 06-06-2009, 09:06 PM
BillsFan's Avatar
Ridin' Dirty #64
BillsFan is offline
Leveling Kit? Leo 6.7L Cummins (2007.5-2011) 5 12-18-2007 03:28 PM
Leveling Kit Mbixler 2008-2010 6.4L Power Stroke 3 11-23-2007 10:11 PM
leveling kit kaskin2-6.0 General Ford Truck and Excursion 13 10-11-2007 05:21 AM
Leveling kit USAFdieselman Whats Been Sold 1 07-20-2007 09:25 AM
Leveling Kit BillsFan Supporting Vendors Forum 2 07-06-2007 09:20 PM
