The light wont work at all. Chased the wires, nothing loose. Not really a problem for me just thinking about anyone of my family that may drive my truck 1 day. Any thoughts or ideas?
What am i saying? Someone else drive my truck? :haha
Can you feel the transmission come out of overdrive when you push the button? If so then the light might be bad if not then something may be wrong with the transmission or computer. Just a thought.
Nope. The tranny functions great, it's just the light. My question is can I replace the light without replacing the whole shifter. Or could it be connected to something else. I just cant see a single fuse being used JUST to run that little light.
Did you try activating the switch while pulling the gear selector toward you? Mine doesn't light (or engage/disengage) either, until I pull the selector about midway and then try the switch :bang ...then everything works great.
I guess its a short that I just haven't gotten around to tracing yet. I hate electrical problems!!!
It's almost certainly the wiring at the base of the shifter lever. Remove the upper column surround (have to pull the key to get it off, but it's easy). The wiring coming out of the base of the shifter may be severed, or may look ok... but it isn't. I was able to solder mine back together. Works fine now.
cheers!
Had a similar problem, started off not working in drive, but in park, 1st, 2nd or neutral
it would work.. replaced the shifter for around 30 bucks brand new from ford.. problem fixed...good luck..
Related Threads
The Diesel Garage
1.2M posts
57.3K members
Since 2005
