7.3 won't start... any ideas - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by triton, this thread has received 12 replies and been viewed 3207 times.
post #1 of 13 (permalink) Old 06-06-2009, 04:08 AM Thread Starter
my PSD 7.3 was parked on a slight incline. It started and drove off a little ways then spit and sputtered then died. It won't restart. I checked the oil which was a little low.... added 3 qts and it's where it should be on the stick.
I replaced the CPS about a year ago but, figured I'd change it again.... nothing. It turns over and acts like it wants to start sometimes but, mainly just bellows a lot of white smoke as if it's just dumping fuel ( flooding )
Put it on a scanner which showed no codes present. The oil and fuel filter was changed a month ago along with new air filters. New GP's about 2 years ago but, never changed the relay.
any ideas would be greatly appreciated
triton is offline
post #2 of 13 (permalink) Old 06-06-2009, 04:44 AM
plainredtruck's Avatar
Images: 11
Sounds either injector related or, well, injector related.
I'll pick Jody's brain tomorrow unless you're gonna be here.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #3 of 13 (permalink) Old 06-06-2009, 04:49 AM
F350-6's Avatar
How long was it parked on the incline? How full is the tank? Does the tach bounce while cranking? WTS light come on and go off like normal? Oil level in the HPOP good?
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 380,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350-6 is offline
post #4 of 13 (permalink) Old 06-06-2009, 04:50 AM Thread Starter
Yeah, Raymond... I'm in Commerce now and will be there in the morning. My plan was to pick his brain also but, figured there was a knowledge from here to be had.
I wish I had a 7.3 manual... it would help a lot.
triton is offline
post #5 of 13 (permalink) Old 06-06-2009, 05:09 AM Thread Starter
only a couple hours. The tank is very low on fuel but, I pulled the water drain and fuel came out....don't think the filter was dry. Yes, the WTS light is working fine. I never checked the HPOP for one cause I don't know where it's at and another, because I know nothing about the 7.3. It's also a van so everything is very difficult to get too.
One thing I noticed is the oil psi doesn't come up until it's be cranking for a while. Then it starts to really drain the battery and blow white smoke ( definitely fuel ) . Is it normal to come up on psi late like that ?
triton is offline
post #6 of 13 (permalink) Old 06-06-2009, 05:13 AM
TwinStacks
SmknDzl's Avatar
could be the fuel pump. when mine went bad it happend out of the blue. pulled out the driveway, spit and sputtered and then died. when cranking it would blow out white smoke.
the pump would come on and you could her it spin but something inside was broken and wouldnt pull the fuel.
just some food for thought...good luck
Chris Cayer- www.facebook.com/SmknDzl or www.myspace.com/smkndzl send a request
Early '99 Black Lariat F-350 cclb dually-TS 6 position, AFE StageII, Autometer UltraLite Gauges, 6" Turnout Stacks, Muffler/Cat Delete, Built Trans from RacerX with .670 Line Mod Valve and Full LockUp Valve, 6.0L Trans Cooler, Boost Relief Valve, Oil X-Over, 5% Tint Around With 20% On The Windshield and 5% Strip On Top, Tinted Tail Lights, 2003 Clear Headlights, VisionX 8K H.I.D. Kit, JVC InDash DVD, APS997 Remote Start and Alarm, Painted Grille and Mirrors, WhiteNight Reverse Lights
Competition Cobra29, DaveMade Comp 2x2, 2x4 and 5pill boxes on VOLTS, Modified Wilson 5000...YEAH IM TALKING
Nathan Airchime P5 Train Horns @ 200PSI
SmknDzl is offline
post #7 of 13 (permalink) Old 06-06-2009, 05:16 AM Thread Starter
definitely will check that. I would think though with all the smoke it's pumping fuel.... too much it seems to the point it's flooding
triton is offline
post #8 of 13 (permalink) Old 06-06-2009, 06:26 AM
BillsFan's Avatar
Similar situation just happened to me, was the IPR.
and Bob @ DieselSite!
TDG Singles Club Member #73
Ridin' Dirty #64
BillsFan is offline
post #9 of 13 (permalink) Old 06-06-2009, 12:17 PM Thread Starter
what is the IPR ?
triton is offline
post #10 of 13 (permalink) Old 06-06-2009, 02:01 PM
BillsFan's Avatar
Injector Pressure Regulator
The tech told me the truck needs a certain amount of fuel pressure to start and if the IPR fails you don't get the required pressure.
Ridin' Dirty #64
BillsFan is offline
Strange Cold start/no start/start changexlt 2003-2007 6.0L Power Stroke 7 12-23-2008 10:00 PM
04-17-13 Hard Start Or No Start - Gpcm Connector Service Kit Available - 6.0l Engine Squatch Ford Oasis requests 0 03-23-2007 12:55 PM
Wont start, any ideas? puckett 5.9L Cummins 12 Valve (1994-1998.5) 6 01-17-2007 01:41 PM
Any ideas on why truck didn't start Snake 2003-2007 6.0L Power Stroke 7 12-23-2006 12:51 AM
CRANK NO START, HARD START, RUNS ROUGH AT IDLE - 6.0L 2005 F, E-Series,and Excursion PSDPlayer 2003-2007 6.0L Power Stroke 0 10-08-2005 08:32 AM
