The Best Set Of Batteries?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Stroker01, this thread has received 28 replies and been viewed 2427 times.
post #1 of 29 (permalink) Old 06-06-2009, 07:08 PM Thread Starter
Stroke 'em!!!
Stroker01's Avatar
My motorcraft batteries have died on me after two years of use. So I was wondering what batteries would be better than the motorcrafts other than the high dollar optimas?
2001 F-250 7.3L, 2wd SRW, Straight Piped with a 25in long Black 6in Tip, Semi Air horn, CCV mod, Zoodad mod, Foil Delete, DIY Intake, Ravelco Anti-Theft Device, issopro gauges.
See videos of my truck at http://www.youtube.com/DieselStroker01
Stroker01 is offline
post #2 of 29 (permalink) Old 06-06-2009, 07:18 PM
The autozone duralast gold are the best value. Consumer reports rated them the same (performance) as interstate but they are like 1/2 the price. I've had mine for 4 years and they are still good. They're good batteries and have a great warranty, I use 'em in everything.
mckey73 is offline
The Following User Says Thank You to mckey73 For this addition to TDG:
D-Man (06-09-2009)
post #3 of 29 (permalink) Old 06-06-2009, 07:21 PM
4cstr's Avatar
Images: 35
I had some batteries from Advanced Auto. Biggest battery I could buy to fit. They were awesome. I even messed up and had a loose connection to where I was starting the truck with one battery only during the fall for a few weeks. Truck turned over slow...but always started. I killed them last winter when my GP relay went out. Because I was in "little town" Iowa..ended up buying very expensive Interstates :
~Dave~
4cstr is offline
post #4 of 29 (permalink) Old 06-06-2009, 07:22 PM
I run interstates whenever I can. Talk to your local interstate truck man and see if he can get you blems. For one reason or another the dealer warrenty's them bad but when they get back to the DC they are tested. they have blems that are 100% good but scratched up. in MT they are $50 for anything but the semi batteries.
FastCR is offline
post #5 of 29 (permalink) Old 06-06-2009, 07:35 PM Thread Starter
Stroke 'em!!!
Stroker01's Avatar
Yeah I have heard the interstate megatrons are good batteries.
post #6 of 29 (permalink) Old 06-06-2009, 08:31 PM
git-r-done
TSGS69400's Avatar
I have great luck with energizers.
idk who makes them but they last the longest.
Thad Seybert
2008 F-350 crew cab short bed Lariat 4x4 6.4 with 3.73's Spartan flash update 250 210 175 150, S&B intake, MBRP cool duals, Rockford amps, Infinity speakers, Tuff Tonneau,
1996 F-250 extended cab short bed 4x4 7.3 5-spd with 3.55's , DIY STG 1's, 4" Diamond Eye duals, DIY Intake, dp tuner, Cobalt gauges, Adrenaline pump, SD springs, D66 turbo, 6.0 intercooler, Custom electric regulated fuel system, Truetrac.
TSGS69400 is offline
post #7 of 29 (permalink) Old 06-06-2009, 10:19 PM
Fddriver2's Avatar
Another vote for Interstate, they have 1000CCA batteries.....
2002 F-250 XLT CC SB\HPX\ITP prepump mod\Harpoon\DI 65psi fuel shim\4" SS turbo back Magnaflow\Fumoto\FTVB\Edge Evolution2\Zoodad\2008 Diff cover\V-10 trany cooler
Fddriver2 is offline
post #8 of 29 (permalink) Old 06-07-2009, 02:22 AM
what about the Sears Die Hards ???
powerstrokemike is offline
post #9 of 29 (permalink) Old 06-07-2009, 03:16 AM
i switched mine over to a set of type 31 International batteries a few years back and they've been great. had to do some modifications to the battery trays to get them to fit ( they were a little too tall ) but it was totally worth it.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. BDP modded IDM. Heim joint clutch linkage. Adrenaline HPOP. LUK SMFW. DIY Elec. Fuel. FS1282, FF5230 fuel filters.
sdan27 is offline
post #10 of 29 (permalink) Old 06-07-2009, 03:37 AM Thread Starter
Stroke 'em!!!
Stroker01's Avatar
Well i went with the Duralast Golds for the price. So Ill see if they do me good.
Batteries gone bad Diezel Dawg 1994-2003 7.3L Power Stroke 11 01-06-2009 04:12 PM
Batteries 7.3stroker281 1994-2003 7.3L Power Stroke 8 01-06-2008 04:04 PM
Batteries powerstroke7.3 1994-2003 7.3L Power Stroke 12 10-26-2007 12:53 AM
CAT batteries for us Extended Power 2003-2007 6.0L Power Stroke 14 09-27-2007 01:33 PM
Batteries POWER STROKE 99 General Ford Truck and Excursion 9 04-18-2007 01:22 AM
