Serious HOPPING!!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TSGS69400, this thread has received 10 replies and been viewed 1499 times.
post #1 of 11 (permalink) Old 06-08-2009, 04:53 AM Thread Starter
git-r-done
TSGS69400's Avatar
Serious HOPPING!!!
OK, It is all starting now. Power + Traction = Hopping.
I am looking for some traction bars and am debating on wether to make my own or buy a set.
If I buy a set it will need to be reasonable in price.
What are the suggestons.
I have considered Farmboy, Superlift, Caltracs, ect
Thad Seybert
2008 F-350 crew cab short bed Lariat 4x4 6.4 with 3.73's Spartan flash update 250 210 175 150, S&B intake, MBRP cool duals, Rockford amps, Infinity speakers, Tuff Tonneau,
1996 F-250 extended cab short bed 4x4 7.3 5-spd with 3.55's , DIY STG 1's, 4" Diamond Eye duals, DIY Intake, dp tuner, Cobalt gauges, Adrenaline pump, SD springs, D66 turbo, 6.0 intercooler, Custom electric regulated fuel system, Truetrac.
TSGS69400 is offline
post #2 of 11 (permalink) Old 06-08-2009, 07:44 AM
joebob3093's Avatar
Send a message via Yahoo to joebob3093
i think i will soon be making my own set
{95 F250 Powerstroke XLT} 5 spd, Wildman 6 pos. chip, custom IC, ADs, AFE stage 2 intake, 3" down pipe to custom 5in stack. EBPV break, shimed FPR, idm mod by mattymx, CCV mod, Leveling Kit, diprocol egt and boost guages.
joebob3093 is offline
post #3 of 11 (permalink) Old 06-08-2009, 12:35 PM Thread Starter
git-r-done
TSGS69400's Avatar
It seems as though it would be the most cost effective alternative.
I am debating the single bar or the dual bar design.
Thad Seybert
post #4 of 11 (permalink) Old 06-08-2009, 03:23 PM
beware the dark side
if you can weld it is cheaper to just build your own bars. I built mine and it only cost me about 150 bucks. get some round tube and some tractor 3rd link bars and weld them up. I made mine single bar which is what alot of the guys on here and that i have seen at the pulls have. i made my mounts myself for the frame and for the axle.
2003 F-350 XLT 7.3L 4X4 Crew Cab, 3.73, Custom built 4R100, AFE intake, Turbonetics BB Turbo W/1.0 A/R exhaust housing, 238/100% Hybrids from Jim @ Rosewood, 5 inch exhaust w/ 6 inch stacks, Tuned my Matt @ Gearhead, Autometer colbalt gauges, Custom built traction bars, viair dual compressor onboard air system. Mickey Thompson Classic II Rims with 315/75R16 BF Mud Terrains, and 4 inch Rough Country lift kit
New Truck: 2000 F-450 XL 7.3L Standard Cab, 6 Speed Stock for now
Trailers: 1999 Jayco 30' 5th wheel
2004 Wells Cargo 20' enclosed trailer (portable shop)
Its not how fast you get there but how much you can pull on the way there.
vader's fury is offline
post #5 of 11 (permalink) Old 06-08-2009, 10:42 PM Thread Starter
git-r-done
TSGS69400's Avatar
Oh Ya I can weld no problem it is simply taking the time haha.
I actually have polyurethane bushings which have large bolt holes and they would insulate from harshness as well.
I designed an auto adjusting set for my 08' but just havent built anything yet.
Thad Seybert
post #6 of 11 (permalink) Old 06-09-2009, 04:03 PM
sounds like you got it figured out then. The only thing that i can think of is the poly bushings might limit your articulation some but not sure. I agree finding the time can really be a pita sometimes. good luck and let us know how they turn out.
post #7 of 11 (permalink) Old 06-09-2009, 10:38 PM
I built some using two bars and a shackle. Works great and doesn’t bind towing or offroad.
Dana60, 4'lift, 35's, Garage built traction bars headache rack and bumpers, fuel tanks, 2 10’s built in the back seat, lost of lights, Intercooler, ATS’ turbo housing, injectors, DP tuner, 4” exhaust, AFE intake, Exhaust brake, CB radio, clutch, 180,000 miles and still going!!!
hay hauler is offline
post #8 of 11 (permalink) Old 06-10-2009, 09:12 PM
Turbo Freak
Stinger23's Avatar
I was having the same problems when I had stock tires/wheels. Upgraded to 18's with bigger tires and less air pressure and now I have no wheel hop issues...
'00 PowerStroke 7.3 6-Speed CrewCab Short Bed 2WD--Purchased December '07--
Mods : 18x9 Moto Metal 958's w/265-65 Nitto's Terra Grapplers, Boost & Pyro Gauges, 7-Position DP-Tuner, DIY Intake, 4" Magnaflow Exhaust, South Bend Clutch, Sony 12" Sub/Enclosure, Kicker 750w Amp, '02 Headlights, Billet Grill,Tow Mirrors,
Coming Soon:Boost Controller, Leveling Kit, Tint
Stinger23 is offline
post #9 of 11 (permalink) Old 06-11-2009, 03:23 PM
You might not have any wheel hop issues now with the bigger tires but i bet if you watch when you take off you got real bad axle wrap. The only way to cure this completely is some sort of traction device.
post #10 of 11 (permalink) Old 06-11-2009, 04:28 PM
CrowsSynthetics's Avatar
Send a message via Yahoo to CrowsSynthetics
Post
I have never built a set but I do weld it would seem that square bar stock would be stronger and easier to fab.
Bill
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
Amsoil 3000 5w 30 ,Amsoil EaAU Air Filter ,Amsoil Pre filter-EaPF13,
Amsoil Dual Remote By-pass BMK-16A, Amsoil ATF & Transfer case, Amsoil 75w-140 fluid front & rear end, Amsoil Antifreeze Fluid
Edge with Attitude, 4" Turbo Back Exhaust,
5" SS Tip
, Transmission Magnefine filter, Sportman Tonneau Cover & Bush Fender Flairs
Now in the stable a new Black 2009 Jetta Sedan TDI
CrowsSynthetics is offline
Skipping/Hopping on Concrete Freeways IdahoF350 General Ford Truck and Excursion 8 06-01-2007 08:00 PM
