speedo needle adjustement?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 99fordtruckguy, this thread has received 0 replies and been viewed 767 times.
post #1 of 1 (permalink) Old 06-09-2009, 12:49 AM Thread Starter
I just added a white face gauge cover (the APC plastic sticker kind) to my stock dash gauge cluster. Looks real good. When I removed the needles to replace the black with white plastic, the speedo needle apparently did not get put on back in the exact right spot as before. I place it against the rest/stop, put after a test drive it now rest about at 8mph when parked. So I am now reading about 8mph or so fast during all speeds. It's not too difficult to pull off the dash trim bezal and clear lens to access the cluster and move the needle again, but I was hoping for a faster way to adjust it. Since it's controled by the VSS and ECM will an AE or a similar tool back the needle down for me, or must it be hand adjusted? Thanks for any help.
99fordtruckguy is offline
air needle bounce when applying brakes???? lastgoodusername Medium and Heavy Duty 2 01-29-2009 03:28 AM
boost gauge needle stuck midwestoffroad 1994-2003 7.3L Power Stroke 0 03-14-2008 08:42 PM
needle bearings barnbridge 2003-2007 6.0L Power Stroke 0 02-02-2008 03:19 PM
Boost Gauge-needle bounces around 04Stroker 2003-2007 6.0L Power Stroke 11 07-14-2007 10:24 PM
Need speedo help on 07 F 250 firedude167 2003-2007 6.0L Power Stroke 8 07-06-2007 10:22 PM
