routing MAP to the hot side... AND cold side? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Sleeperstroke, this thread has received 2 replies and been viewed 1202 times.
post #1 of 3 (permalink) Old 06-10-2009, 02:16 AM Thread Starter
Riding solow on the Hog
Sleeperstroke's Avatar
Awhile back there was a thread that showed a reroute of the map line to the hot side of the intercooler circuit, siting quicker throttle response. I was all set to perform this mod, but wanted to drill and tap the spider pipe instead of having to weld a bung into the hot side pipe itself. Would the drill/tap/installation of a barb/npt be acceptable? Its quite a bit closer than the original threaders route which was more than half way down the hot side pipe.... THEN I got to thinking further... What if one Yd the cold side and hot side connections so that the MAP was reading a cumulative from both? Ive no idea what this would do..... Anyone have any speculation/experience as to why this should or should not be done? NEED INPUT.
"MOby" The big white bio-burning 03 7.3 4x4. 6637, straight piped stock exhaust, and a new "secret" blend of Haul asBLEEPsing mods and upgrades. Suffice to say, its still not the fastest, but its quick enough to worry lots!
Sleeperstroke is offline
post #2 of 3 (permalink) Old 06-10-2009, 03:41 AM
joebob3093's Avatar
Send a message via Yahoo to joebob3093
it should be fine to drill and tap the spyder. csipsd was the one who posted the original thread you could ask him.
{95 F250 Powerstroke XLT} 5 spd, Wildman 6 pos. chip, custom IC, ADs, AFE stage 2 intake, 3" down pipe to custom 5in stack. EBPV break, shimed FPR, idm mod by mattymx, CCV mod, Leveling Kit, diprocol egt and boost guages.
joebob3093 is offline
post #3 of 3 (permalink) Old 06-20-2009, 01:24 AM Thread Starter
Well heres the final deal. I went ahead and drilled/tapped the spider, and mounted up a 1/4 barb/NPT fitting. I left off routing hot/cold, calculating that it was rather superfluous, and would probably diminish the benefit of the hotside route, after all... Yes, even with the chip turned up it made a difference. Throttle response is more immediate and definite.
04+ CR cold side intercooler pipe Robts Whats Been Sold 0 03-02-2009 04:05 AM
size of opening on stock intercooler(cold side) strokin6L 2003-2007 6.0L Power Stroke 1 11-20-2007 08:37 PM
Thermal Taped Cold side AllOut0606 1994-2003 7.3L Power Stroke 6 07-08-2007 10:54 AM
Cold Side intecooler tube AllOut0606 1994-2003 7.3L Power Stroke 6 06-13-2007 09:41 PM
Side bar team_penin Site Information 9 02-15-2006 05:02 PM
