help? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Stroker99, this thread has received 2 replies and been viewed 702 times.
post #1 of 3 (permalink) Old 06-10-2009, 07:11 PM Thread Starter
help?
Took the truck to the stealership for a buzz test results 6 is dead and 4 has a weak signal they thought it was uvc harness just chaned before I brought it in checked connections all good replaced cylinoids on injectors still acting up only thought is connection on the outside of the valve cover. any thoughts
99 psd 123000mi supechips programmer 4" magnaflow exausht.
Stroker99 is offline
post #2 of 3 (permalink) Old 06-10-2009, 07:27 PM
plainredtruck's Avatar
Images: 11
Couldn't quite follow what you were stating there, but I suggest you start with replacing the UVC harness if you haven't already.
It's fairly inexpensive compared to swapping injectors.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #3 of 3 (permalink) Old 06-11-2009, 02:05 AM
Swap either #6 or #4 for a known good injector and test again. If the same cylinder buzzes weak or dead, then it's an electrical/wiring issue. If the same injector itself fails on a different cylinder, than it's a bad injector.
Pocket is offline
