99 f450 starving for fuel - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by squishy, this thread has received 9 replies and been viewed 1766 times.
post #1 of 10 (permalink) Old 06-11-2009, 05:37 AM Thread Starter
I am about to burn this truck to the ground. We started having problems with it smoking and running out of fuel under load we blew back the line from the pump to the tank and it made no diffference. We then replaced the pump thinking that it was on its way out .......nothing the truck works fine when it is cold but as soon as it heats up thats when we have problems. I have removed the fuel filter from the housing and turned on the key and it just trickles into the housing. I dropped the fuel tank several times thinking that the pickup might be blocked but nothing I plugged the fuel pick up tube and blew into it and does not seem to leak. We replaced the fuel line from the tank to the pump to no avail. We ran the truck with the fuel pick up in a bucket and the truck worked okay we did not get a chance to run it hard with the bucket. Please help before I loose my sanity
squishy is offline
post #2 of 10 (permalink) Old 06-11-2009, 11:32 AM
plainredtruck's Avatar
Images: 11
Have you tried a different pump?
It certainly sounds like you've covered everything else.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
The Following User Says Thank You to plainredtruck For this addition to TDG:
squishy (06-12-2009)
post #3 of 10 (permalink) Old 06-11-2009, 03:56 PM Thread Starter
We have tried a new pump as well as the old pump and still get the same results
squishy is offline
post #4 of 10 (permalink) Old 06-11-2009, 04:15 PM
Cratos's Avatar
have you check the line from the pump to the top of the motor you may have one of the felx lines kinked or going bad on the inside. you should have lots of fuel going to the bowl .
Cratos is offline
The Following User Says Thank You to Cratos For this addition to TDG:
post #5 of 10 (permalink) Old 06-11-2009, 06:14 PM Thread Starter
We have not checked the line from the pump to the filter housing, but when the truck has acted up we checked the output from the pump and there is very little flow.
squishy is offline
post #6 of 10 (permalink) Old 06-11-2009, 06:16 PM
Images: 11
Yep, check the pump without a fuel line attached. Pump into a bucket to see the flow.
Starting to sound like a fuel line is kinked or corroded as Cratos suggested.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
Mafia # 27
post #7 of 10 (permalink) Old 06-11-2009, 06:35 PM
Cratos's Avatar
Dont know what your you have, but you may also have a pluged vent. try leaving the cap to the tank you are running losse or off and see if the flow from the pump is better also check your voltage at the pump,
pull the line at the pump first and check the flow then up top .if it ig good at the pump but not ant the top you have a bad line.
Cratos is offline
post #8 of 10 (permalink) Old 06-12-2009, 07:07 AM Thread Starter
Thumbs up
We got it solved. We dropped the tank for the 7th time today and pulled this plastic thing that is attached to the pickup tube it also has the fuel return line attached to it as well. We pulled it off and actually found that it could be taken apart what we found inside were two mesh tubes that were plugged solid with crap we cleaned them up and put it all back together and took it for a test drive. It felt like I was driving a new truck lots of power. So if you guys experience the same problem check that thing out you may suprised how much crap can accumulate over the years
squishy is offline
post #9 of 10 (permalink) Old 06-12-2009, 11:30 AM
Images: 11
Glad you found the problem, but I thought you already had done that by your earlier description.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
Mafia # 27
post #10 of 10 (permalink) Old 06-13-2009, 06:18 AM Thread Starter
We did everything but pull that plastic cannister apart. We did not think that it was something that could be taken apart.
squishy is offline
F450 4.88 Mpg MstHillFarms 2008-2010 6.4L Power Stroke 20 01-26-2009 11:47 PM
97 vs. 99+ F450 sirscoolrascal General Ford Truck and Excursion 1 04-28-2007 04:13 PM
F450 over29 2008-2010 6.4L Power Stroke 0 02-03-2007 03:43 AM
F450 with 4.88 over29 2008-2010 6.4L Power Stroke 20 01-31-2007 05:20 AM
