OBS Window Motor Replacement - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by genie144, this thread has received 4 replies and been viewed 2299 times.
post #1 of 5 (permalink) Old 06-12-2009, 02:16 AM Thread Starter
Does anyone have tips on replacing the window motor? The rear passenger motor in my crew cab is going out. I need to replace it and was hoping someone had an article or suggestions.
Sam
The Trash Truck
96 CC F350 SRW - Built for SVO and mileage
Go Green - HotFox, Dual Heated Dahl 100s, Fuel Filter Coolant Wrap, ArcticFox
Go Fast - Hybrids, H2E, 6.0 IC, Fuelab, BTS 144.2/291.5 uncorrected
thanx go to
Rockin-S-Performance - Install, tech support, and advice
Diesel Innovations - Killer Deal on Parts
Tony Wildman/SWAMPS - Tuning
genie144 is offline
post #2 of 5 (permalink) Old 06-12-2009, 03:30 AM
that's funny because my name is Sam too and I have the same problems on my driver side window
cong is offline
post #3 of 5 (permalink) Old 06-12-2009, 04:57 AM Thread Starter
Well that makes two of us looking for the information. I searched and couldn't find anything. Someone care to help?
Sam
The Trash Truck
thanx go to
genie144 is offline
post #4 of 5 (permalink) Old 06-12-2009, 06:35 AM
4play's Avatar
remove door panel, then locate motor behind door skin. from the location of the motor you will find its mounted by 3 bolts usually 5/16 or 8mm heads. if the bolts are not visible there is usually a circular indention in the door skin where you can drill the circular indent area to access the motor bolts.
if you do not want to drill the indents for the motor bolts then you will need to knock the centers out of the rivets and drill the 1/4" rivets that mount the window regulator to the door. remove the regulator and replace the motor and re-rivet or mount the regulator. if you go back with rivets you need a big rivet gun that can handle 1/4" rivets too.
4play is offline
post #5 of 5 (permalink) Old 06-12-2009, 07:28 PM Thread Starter
Sounds good. I will take a look this afternoon. Hoping it is not riveted...
Sam
The Trash Truck
thanx go to
genie144 is offline
Difference Motor replacement Intrailhunter 7.3L and 6.9 IDI (Pre 1994) 7 02-17-2008 08:55 PM
window stickers RebelBullrider The Detailing, Paint & Bodyshop 6 02-15-2008 09:45 PM
Window Darvin Whats Been Sold 2 12-06-2006 04:04 AM
Rebuild /replacement motor. KERR 5.9L Cummins (2003-2007.5) 1 09-06-2006 08:22 PM
