driving down the road sideways - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 1995nicholas, this thread has received 6 replies and been viewed 3685 times.
post #1 of 7 (permalink) Old 06-12-2009, 07:44 PM Thread Starter
95 f250 psd. everyone tells me that my truck goes down the road doglegged(not straight). i put a 4" lift on it with 315's. is there any thing i can do to get it to go straight again?
1995nicholas is offline
post #2 of 7 (permalink) Old 06-12-2009, 07:50 PM
plainredtruck's Avatar
Images: 11
Has it ever been involved n a crash?
Check the frame to see if it's straight.
Otherwise
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #3 of 7 (permalink) Old 06-12-2009, 08:18 PM
Banned
It it just a looks thing or are you seeing abnormal tire wear? You could have it thrown on a frame rack and take some measurements to see what night be crooked or tweaked. If it's a tire wear issue a 4 wheel alignment might fix it depending how bad it is.
wastedwagesracing is offline
post #4 of 7 (permalink) Old 06-13-2009, 03:34 AM
buffalobob's Avatar
if the lift has blocks on the rear the stud for the spring pack bolt could be off center f-r. if you replaced the spring pack the center could be different between sides. i dont think it would take much to throw one end of your axle an inch or so off. i had an old chevy that the axle slipped on the spring about 1/2" and threw everything out of whack
2011 silverado lt, crewcab, short bed, 4X4, d-max/ allison
buffalobob is offline
post #5 of 7 (permalink) Old 06-13-2009, 03:37 AM
joebob3093's Avatar
Send a message via Yahoo to joebob3093
i was going to say check the center pens on the rear springs and the lift blocks. or take it to a shop and have them look at it.
{95 F250 Powerstroke XLT} 5 spd, Wildman 6 pos. chip, custom IC, ADs, AFE stage 2 intake, 3" down pipe to custom 5in stack. EBPV break, shimed FPR, idm mod by mattymx, CCV mod, Leveling Kit, diprocol egt and boost guages.
joebob3093 is offline
post #6 of 7 (permalink) Old 06-13-2009, 04:34 AM
Resident GINGER
CFRO's Avatar
Send a message via MSN to CFRO
Well my truck looks like it's going sideways when your following it, but it's because the front axel is wider than the rear. Have you seen your truck driving down the road, or is it just what your buddies say. I would get someone else to drive the truck and get a good view before i started putting money into it.
08 Ranger Grabber Orange. XLT 4x4 5 Speed Manual Super cab. Sirius. Silvana 9007 and 9415's. Amsoil 0w30 (Mileage Maximizer). Dee Zee Powder Coated Tool Box (PEELING). Dual 3' Fire Sticks. Cobra 75 X.
94 F-350 CC LB 5 -Speed. 4.10's. MBRP. Single Mass. 265/75's on 16x8's. Uniden CB. 3' Firestick.
Single club # 61
CFRO is offline
post #7 of 7 (permalink) Old 06-13-2009, 07:36 PM Thread Starter
yea it was in a crash. a car passed the center line and hit me in the left front tire. peeled the bead for the rim back and when i did the lift i found the center brackets for the a arms were broken! there are blocks in the rear with center pins.
no i have not seen the truck go down the road. so I'm not to sure what it looks like go down the road. there is no abnormal tire wear.
Drinking and driving. madville The Parking Lot 18 01-15-2009 12:03 PM
I'm driving along today... Zaairman The Parking Lot 7 10-31-2007 01:00 AM
Get a little sideways! gregrob The Parking Lot 2 04-29-2007 02:43 AM
Driving along and died deerrun 2003-2007 6.0L Power Stroke 5 01-28-2007 03:09 AM
This is driving me nuts... partsguy662 The Parking Lot 12 10-13-2005 01:39 AM
