engine swap ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bandersnatch, this thread has received 8 replies and been viewed 1722 times.
post #1 of 9 (permalink) Old 06-13-2009, 07:54 AM Thread Starter
engine swap ?
I have a 03 6.0 with an auto tranny and the whole engine compartment was burned. the fire stopped at the firewall .I'm looking at a donor truck that is a 03 7.3 stick tranny .I was wondering if the computer and wiring will work. thank you. brian
1999 F350 EXT cab long bed dually. Auto trans
k/n intake,Magnalfow 4" turbo back exhaust, pyro, boost and trans temp gauges.DP tuner,no start,stock,60hp tow,80 eco,120 race,140 arg.
2006 f250 4dr short bed. auto trans, Studs, Airdog2, boost,trans,pyro,fuel gauges, SCTx3,banks intake and exhaust ,coolant filter, egr welded up,ccv reroute and some 20" hd wheels.
Bandersnatch is offline
post #2 of 9 (permalink) Old 06-13-2009, 08:20 PM
EB.Bldr's Avatar
Not sure exactly what wiring your refering too. I would think it could be made to work if that what your wondering.
You could try posting in the "diesel conversion" section as on of the major parts of swapping an engine envolves electrical and there a few that have completed some different projects over there.
Best of luck.
EB.Bldr is offline
post #3 of 9 (permalink) Old 06-13-2009, 10:15 PM Thread Starter
wondering if the 7.3 stick engine wiring harness and the computer will hook up to the 6.0 automatic tranny dash harness and if that computer will work for the the auto tranny because i would rather have the auto. thanks
post #4 of 9 (permalink) Old 06-14-2009, 01:53 AM
EB.Bldr's Avatar
Your going to need the 6.0 wiring and computers.
EB.Bldr is offline
The Following User Says Thank You to EB.Bldr For this addition to TDG:
Bandersnatch (06-14-2009)
post #5 of 9 (permalink) Old 06-15-2009, 05:11 AM
StrokerDude's Avatar
Absolutely no way that a 7.3 harness is gonna work on a 6.0 truck.
Alex C.
StrokerDude is offline
post #6 of 9 (permalink) Old 06-16-2009, 06:56 AM Thread Starter
i would be replacing the 6.0 with the 7.3. just wondering if the wiring connections at the firewall would be the same and if the computer would work getting switched from a stick to an auto or can it be re flashed . sorry if im not explaining myself very well.thanks
post #7 of 9 (permalink) Old 06-16-2009, 02:34 PM
bpogue's Avatar
No way it would work without completely rewiring everything. The computers are different. The sensors are different. The harnesses are different. It could be done, but it would be complete re wire job.
1996 Int 4700, 175hp DT466, 5 speed, 2x rear end, service body
2001 F350 SRW flatbed, 4x4, crew cab
1978 International F2275 Dump Truck
1996 NH LX665, steel tracks on foam filled tires
2005 Tackeuchi TB145
2003 Takeuchi TL150
Case 850B Highlight, 4 way bucket
bpogue is offline
The Following User Says Thank You to bpogue For this addition to TDG:
Bandersnatch (06-19-2009)
post #8 of 9 (permalink) Old 06-16-2009, 04:27 PM
not worth it at all
Alex C.
post #9 of 9 (permalink) Old 06-18-2009, 12:28 AM
CSIPSD's Avatar
You need everything from th donor truck, complete cab harness and motor harness.
CSIPSD is offline
The Following User Says Thank You to CSIPSD For this addition to TDG:
Engine Swap 1964reo 5.9L Cummins (Pre 1994) 10 01-08-2008 04:53 AM
6.9 to 7.3 engine swap alr 7.3L and 6.9 IDI (Pre 1994) 0 11-14-2007 04:45 PM
99 to 97 engine swap moboy 1994-2003 7.3L Power Stroke 3 08-23-2007 05:04 PM
engine swap gear24 1994-2003 7.3L Power Stroke 1 08-01-2007 03:44 AM
Engine Swap DieselE 1994-2003 7.3L Power Stroke 4 05-28-2007 02:53 PM
