Manifold to Turbo Exhaust Ideas - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hay hauler, this thread has received 3 replies and been viewed 1179 times.
post #1 of 4 (permalink) Old 06-16-2009, 01:48 AM Thread Starter
95 7.3L. I keep having problems keeping the feeder tubes (what I call the tubes from the exhaust manifold to the turbo) sealed. I only get 40 to 30 thousand miles out of them. I replace the tube when I replace the gasket. The design just isnít that great in my opinion. Any ideas or mods anyone can think of? I have seen the newer ones have flexible portions on the tubes. Can we get these for the OBS trucks? I have seen that some Chevy gasket can be used but I donít see this fixing the problem. I hate doing this job more than once. Any and all ideas are great.
Dana60, 4'lift, 35's, Garage built traction bars headache rack and bumpers, fuel tanks, 2 10ís built in the back seat, lost of lights, Intercooler, ATSí turbo housing, injectors, DP tuner, 4Ē exhaust, AFE intake, Exhaust brake, CB radio, clutch, 180,000 miles and still going!!!
hay hauler is offline
post #2 of 4 (permalink) Old 06-17-2009, 03:34 AM
pontiacross's Avatar
you can buy bellowed up-pipes that will fit it from international.
or you can try and make your own
I did it for an H2E so I dont know why you couldn't do it on your stock turbo.
you can probably weld the pipe to the top flange and then cut it some where in the middle and weld in a flex coupling.
I got mine from verocious motorsports just make sure you get the kind woith the interlock liner
here is how my setup looks
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #3 of 4 (permalink) Old 06-17-2009, 03:48 AM
CSIPSD's Avatar
I built mine to for an H2e...
CSIPSD is offline
post #4 of 4 (permalink) Old 06-17-2009, 07:15 AM Thread Starter
Ok when you both welded them have you seen any problems with the heat affecting the flexible parts? I was looking at some stock ones of off a newer ford and they looked like they could be affected by the welding heat, because of the thin metal. I could see the heat making the metal brittle. I have thought about doing this. I don't know how difficult it would be to do in the truck. It isn't the easiest area to work in to start. I guess I could just make modified ones the same as stock ones on the bench. This might be where I am going to go with this. I am guessing an exhaust brake doesn’t help the situation any.
12v ATS exhaust manifold bmoeller Whats Been Sold 2 06-06-2009 10:40 PM
exhaust manifold village idiot 1994-2003 7.3L Power Stroke 9 01-18-2008 09:41 PM
exhaust manifold POWER STROKE 99 5.9L Cummins (1998.5-2002) 21 03-21-2007 05:36 PM
BD Exhaust Manifold Nasty Girl Whats Been Sold 0 04-29-2006 12:17 AM
24V ATS Exhaust Manifold (NEW) zukgod1 Whats Been Sold 3 02-17-2006 11:28 PM
