Leaking Tranny - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by lawn jockey, this thread has received 3 replies and been viewed 855 times.
post #1 of 4 (permalink) Old 06-17-2009, 04:03 AM Thread Starter
Leaking Tranny
2001 F350 4x4 7.3 130k. When I am in warm weather above 80* my trans. leaks fluid out the dust cover when I go to park the truck. It will stream out and have a small puddle. This only happens when it's hot outside and doing let's say 5mph or slower. The truck is clean underneith so it doesn't leak at high speeds. Normal conditions under 80* I will get one small drip in the driveway. I imagine its a seal. The truck shifts smooth, no chattering, or sounds. It's happend twice. Your thoughts?
lawn jockey is offline
post #2 of 4 (permalink) Old 06-17-2009, 06:09 AM
4play's Avatar
e4OD has been known to piss out of the front pump/convertor seal. most of the time it is during or after towing heavy or when hot.
4play is offline
post #3 of 4 (permalink) Old 06-17-2009, 06:40 AM
joebob3093's Avatar
Send a message via Yahoo to joebob3093
: had a friend who had the pump seal go out and it pissed out a couple quarts a week.
{95 F250 Powerstroke XLT} 5 spd, Wildman 6 pos. chip, custom IC, ADs, AFE stage 2 intake, 3" down pipe to custom 5in stack. EBPV break, shimed FPR, idm mod by mattymx, CCV mod, Leveling Kit, diprocol egt and boost guages.
joebob3093 is offline
post #4 of 4 (permalink) Old 06-17-2009, 10:52 PM
TDG MAFIA MEMBER #77
TooLoudTooBad's Avatar
I have had the same issue. I swaped the 7.3 trans cooler for a 6.0 trans cooler and most of the issue has gone away. The only time it pukes know is if I am pulling a heavy load really slow. Some day I am going to get the seal fixed (Or just get a BTS and not worry about it anymore)
TooLoudTooBad is offline
tranny lines leaking Cozy Homes D-MAX GM Transmissions 1 02-18-2009 03:19 PM
tranny rebuild kits! need help asap tranny is shot...f'in dodge auto trans blksmk 5.9L Cummins 12 Valve (1994-1998.5) 5 12-26-2008 11:55 PM
HPO oil still leaking bluovaltruk01 1994-2003 7.3L Power Stroke 22 04-10-2008 04:39 AM
Tranny fluid leaking lilgsx 2003-2007 6.0L Power Stroke 2 08-05-2007 05:06 PM
Ext. tranny filter leaking...argh !!! Kawis Dad 2003-2007 6.0L Power Stroke 16 11-22-2005 04:56 PM
