Spindle seal or inner seal?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Sleeperstroke, this thread has received 16 replies and been viewed 1820 times.
post #1 of 17 (permalink) Old 06-18-2009, 12:21 AM Thread Starter
Riding solow on the Hog
Sleeperstroke's Avatar
Noticed some splatter drops on the passengers side wheelwell, looked underneath and sure enough, theres gear oil leaking.
SO, did a search on here, which of course made even more questions and really helped very little.....
IS it the inner axle seal?? I checked the pumpkin juice, and its right at level still.... For how long I dont know.
By the way, I realize it probably isnt the spindle bearing seal, but since Im not totally positive...
"MOby" The big white bio-burning 03 7.3 4x4. 6637, straight piped stock exhaust, and a new "secret" blend of Haul asBLEEPsing mods and upgrades. Suffice to say, its still not the fastest, but its quick enough to worry lots!
Sleeperstroke is offline
post #2 of 17 (permalink) Old 06-18-2009, 10:41 PM Thread Starter
Wow, you guys are all over it.
I found out its the axles seals, next to the pumpkin, bleah, looks like Ill be disassembling ye olde front drive axle soon. Flippen axle seals are rather pricey here..
post #3 of 17 (permalink) Old 06-20-2009, 01:37 AM
Kip
In the passing lane
Kip's Avatar
my real axle seal is leaking gonna have to fix it on monday
2005 2500HD DIRTYMAX 6in lift, dual exhaust, afe airbox. Tuner soon to come
2001 PSD shortbed crewcab, ATS tranny edge juice w/attitude, Superchips programmer, Gauges, exhaust, 4inch lift w/35s, (SOLD)
Originally Posted by sledneck57
Your sweating like a queer holding a hot dog.lol.
Kip is offline
post #4 of 17 (permalink) Old 06-20-2009, 04:57 AM
MAFIA MEMBER 106
camojeeper's Avatar
there is a dust seal at the end of the axle and one down inside the diff put a pint of lacqure thinner in it cool and drive about 2 miles with the hubs locked and it will swell the seal
STEVE TDG MAFIA#106
camojeeper is offline
post #5 of 17 (permalink) Old 06-20-2009, 10:15 PM Thread Starter
I hope yer not bsin me, cause Im gonna do it till I can get the time to fix it proper, which wont be for at least two more weeks. Its started to seep even more now.
post #6 of 17 (permalink) Old 06-21-2009, 02:25 PM
Bruno2's Avatar
Steve wouldnt tell you to do something that would hurt your truck . Next time post some more info on your , like year make and model . Specify 4x4 or not and which axle . If you know the make of the axle that wouldnt hurt either (dana 50 or dana 60
Bruno2 is offline
post #7 of 17 (permalink) Old 06-21-2009, 06:00 PM
Yes, if its gear oil its the inner axle seals, there is only grease in the hubs. If its not a bad leak, I'd leave it alone because its a lot of work to pull the axle shafts and carrier to change those seals. If you do change the seals, get the Ford kine, they are much better than the aftermarket seal designs I've seen. Order ahead of time from a place like directfordparts.com and save a lot of $$$ over dealer costs. I bought mine last minute at the dealership for cost+rape after I found the seals included in my install kit were wrong.
cartmanea is offline
post #8 of 17 (permalink) Old 06-21-2009, 08:04 PM Thread Starter
Apologies. Tis a Dana 60 drivers side drop(RC) HP with ball joints not kingpins, 3.73 gearing. The laquer thinner thing seems to work at least in part. I did it this morning, but didnt fit quite a whole pint in. More like 2/3rds of a pint.... Cleaned up the spattering and ooze so I could gauge how much its still leaking. Drove a couple of three miles with the hubs locked up, and then a round trip of about 60 miles, and gosh darned if it didnt significantly slow the seepage! Didnt stop it, but its not spattering and oozing near as much as it was. YAY! Thanks Camo! Nice trick! And thanks cartmanea as well for the link. I guess 114k on the original seals is good enough.... I think Im going to do the ball joints as well since Ill have to basically disassemble the whole dang thing anyways. Wheee!
post #9 of 17 (permalink) Old 06-21-2009, 08:43 PM
When you pull the axle stubs out, if you don't want to replace the $60 hub seals, remove them this way. Instead of driving them out from the backside with a punch like the manual states, use a large pry-bar between the axle tube and u-joint to pull the axles out with the hub seals still intact. And for what its worth, driving around with lacquer thinner in your differential is a very bad idea, just my opinion. There wouldn't be sufficient lubrication between the ring and pinion and it could cause scarring on the gear surface.
post #10 of 17 (permalink) Old 06-21-2009, 10:25 PM
Pro 2A
sirthomas's Avatar
what kind of special tools are needed for this job (such as seal drivers, spreaders or pullers) anyone have a write up on this job.
01 F350 Lariat Crew Cab Short Box 4x4,4" Magnaflow turbo back exhaust,DIY 6637 air intake,Edge Juice with Attitude,Warn Manual Hubs,6.0 Trans Cooler,B&M Trans Temp Gauge,ATS housing,Turbo Master Wastegate Controller,BTS Transmission,CCV mod,coolant filter
TDG singles club member #106
TDG American club member #27
TDG B.O.M.B. squad member #25
Ridin' Dirty Club #32
sirthomas is offline
Door seal mod rdr99 Ford - Modification instructions, Product installs and Tech Articles 11 06-02-2009 07:54 PM
Rear hub seal Kip 1994-2003 7.3L Power Stroke 4 09-29-2007 04:37 AM
crankshaft seal? turbodave 5.9L Cummins 12 Valve (1994-1998.5) 6 08-30-2007 03:14 AM
SEAL Rescue 6Lcummins The Parking Lot 1 04-05-2007 10:32 PM
Oil seal leak 1bully 5.9L Cummins (1998.5-2002) 2 03-29-2007 12:13 AM
