Cant get Torque Conv. Lockup to Work?! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by smokinstroke, this thread has received 6 replies and been viewed 1472 times.
post #1 of 7 (permalink) Old 06-22-2009, 03:01 AM Thread Starter
Second is First Loser
smokinstroke's Avatar
Hey guys, I have done exactly what everyone says and shows to do to make a torque converter lockup on my 2000 and it doesnt work?!! Whats causing it not to work? I t'd into the purple wire with yellow tracer and ran it to a toggle switch then made a short wire that i grounded to a bar under the fuse panel in the cab and ran it to the switch also. Still doesnt work. Any ideas?
2000 Ford F250 AFE stg2 intake, 4" custom exhaust, DP Tuner F5, Transgo Shift Kit, BTS Torque Converter, Raybestos Clutches, ISSPRO Reverse Glow Gauges, Eagle Alloy Wheels, lots of shiney stuff, lots of L.E.D's more to come...
"In the shop getting more ponies as we speak!"
2008 Chevy 2500HD Stainless Rocker Panels, Chrome Bug Shield, Tonneau Cover, more to come...
The Diesel Garage......Can You Keep Up?
smokinstroke is offline
post #2 of 7 (permalink) Old 06-22-2009, 05:52 PM
beware the dark side
make sure that you have a good ground and that the connections are good all the way out to the purple wire. I had the same problem when i hooked mine up and found out that my brand new switch was bad.
2003 F-350 XLT 7.3L 4X4 Crew Cab, 3.73, Custom built 4R100, AFE intake, Turbonetics BB Turbo W/1.0 A/R exhaust housing, 238/100% Hybrids from Jim @ Rosewood, 5 inch exhaust w/ 6 inch stacks, Tuned my Matt @ Gearhead, Autometer colbalt gauges, Custom built traction bars, viair dual compressor onboard air system. Mickey Thompson Classic II Rims with 315/75R16 BF Mud Terrains, and 4 inch Rough Country lift kit
New Truck: 2000 F-450 XL 7.3L Standard Cab, 6 Speed Stock for now
Trailers: 1999 Jayco 30' 5th wheel
2004 Wells Cargo 20' enclosed trailer (portable shop)
Its not how fast you get there but how much you can pull on the way there.
vader's fury is offline
post #3 of 7 (permalink) Old 06-23-2009, 03:44 AM Thread Starter
I even tried 2 switches and it still didnt work.
post #4 of 7 (permalink) Old 06-23-2009, 04:21 PM
where did you tie into the purple wire with yellow tracer at?
post #5 of 7 (permalink) Old 06-25-2009, 04:26 AM Thread Starter
I tied into it down by the tranny the first time and it didnt work. Than I tied it in up by the airbox and it still didnt work??? So I dont know what it is.
post #6 of 7 (permalink) Old 06-25-2009, 04:44 PM
BJS
does the torque converter lock as when the computer instructs it to as normal?
or is it that your lockup switch is just not working?
BJS is offline
post #7 of 7 (permalink) Old 06-27-2009, 10:40 PM Thread Starter
I cant get the lockup switch itself to work. The tc locks up when it is supposed to by the computer
torque converter lockup....or not...! gon2sea 5.9L Cummins (1998.5-2002) 18 07-29-2009 03:27 AM
torque converter lockup? carova_kevin Dodge Performance Forum 5 04-25-2008 06:09 PM
torq conv lockup switch. masonjo 5.9L Cummins (1998.5-2002) 14 09-12-2007 03:29 PM
Torque Converter lockup? Horsehaulin Medium and Heavy Duty 13 06-16-2007 01:03 AM
torque converter lockup? 02psd 1994-2003 7.3L Power Stroke 2 05-30-2007 02:49 AM
