hot side intercooler boot ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Stroker99, this thread has received 4 replies and been viewed 2063 times.
post #1 of 5 (permalink) Old 06-22-2009, 07:17 PM Thread Starter
this weekend towing the trailer going along and all asudden the boot would blow off scared the sh t out of me and the fam tighten the clamp as tight as it would go still blew ps dont have a boost guage stock turbo superchips 1705 programmer any idea
99 psd 123000mi supechips programmer 4" magnaflow exausht.
Stroker99 is offline
post #2 of 5 (permalink) Old 06-22-2009, 10:27 PM
Riding solow on the Hog
Sleeperstroke's Avatar
Yep.
Take the boot completely off, and check the inside for a film of oil. Also check your pipes for oil residue inside. Clean the inside of the boot up real good, and also the outside of the pipes where the boot sits. Re install, and see about doing the CCV mod. (Re routs the CCV hose to atmosphere or to a canister then to atmosphere instead of into the air intake pipe. Keeps the oily residue out of your intercooler system.) Other than that, could be time for new boots.
"MOby" The big white bio-burning 03 7.3 4x4. 6637, straight piped stock exhaust, and a new "secret" blend of Haul asBLEEPsing mods and upgrades. Suffice to say, its still not the fastest, but its quick enough to worry lots!
Sleeperstroke is offline
The Following User Says Thank You to Sleeperstroke For this addition to TDG:
Stroker99 (06-23-2009)
post #3 of 5 (permalink) Old 06-22-2009, 11:54 PM
brendonv's Avatar
Mine did it to me. Took them off and cleaned them with degreaser, been good ever since.
Early 1999 F350 DRW Dump, 6spd 4x4, 4" Turbo Back and DIY Intake
Early 1999 F350 SRW 8' Box, 6spd 4x4 Stock
brendonv is offline
The Following User Says Thank You to brendonv For this addition to TDG:
post #4 of 5 (permalink) Old 06-24-2009, 12:36 AM
F350-6's Avatar
You can also use a shot of hairspray after you clean things up. It provides a sticky surface that aids in holding things together.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 380,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350-6 is offline
post #5 of 5 (permalink) Old 06-24-2009, 03:36 PM
Fddriver2's Avatar
This is what I did... Way better boots. The silicone ones were soft and oil inpregnated......
http://www.dieselsite.com/index.asp?...ROD&ProdID=133
2002 F-250 XLT CC SB\HPX\ITP prepump mod\Harpoon\DI 65psi fuel shim\4" SS turbo back Magnaflow\Fumoto\FTVB\Edge Evolution2\Zoodad\2008 Diff cover\V-10 trany cooler
Fddriver2 is offline
Blown intercooler boot Fireguy 2003-2007 6.0L Power Stroke 14 03-17-2008 06:15 AM
intercooler boot big_rooster 5.9L Cummins (1998.5-2002) 1 09-14-2007 01:03 AM
Intercooler boot sizes xtremexj 2003-2007 6.0L Power Stroke 8 07-24-2007 02:34 AM
intercooler boot Robts 2003-2007 6.0L Power Stroke 3 06-26-2007 06:43 AM
Intercooler boot set 6_Myles 1994-2003 7.3L Power Stroke 5 04-11-2007 04:42 AM
