Engine Cuts Out While Driving? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Stevie Mac, this thread has received 14 replies and been viewed 16025 times.
post #1 of 15 (permalink) Old 06-23-2009, 03:56 PM Thread Starter
2000 7.3 F350 dually. Cutting out just for a second then kicks back in. The service engine light comes on the goes out. I have not had a chance to take truck by to check service code.
Any ideas?
Stevie Mac is offline
post #2 of 15 (permalink) Old 06-23-2009, 05:06 PM
bpogue's Avatar
Sounds like cam position sensor to me. While driving it just dies. Sometimes it will just pick up again and start running again while driving. Occasionally you may have to turn the ignition off and then back on? Easy 15 minute replacement.
1996 Int 4700, 175hp DT466, 5 speed, 2x rear end, service body
2001 F350 SRW flatbed, 4x4, crew cab
1978 International F2275 Dump Truck
1996 NH LX665, steel tracks on foam filled tires
2005 Tackeuchi TB145
2003 Takeuchi TL150
Case 850B Highlight, 4 way bucket
bpogue is offline
post #3 of 15 (permalink) Old 06-23-2009, 05:43 PM
plainredtruck's Avatar
Images: 11
I've had the same problem and replacing the CPS didn't fix a thing.
I still can't track mine down.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #4 of 15 (permalink) Old 06-23-2009, 05:48 PM
********* and Mafia #90
Bcarriveau's Avatar
i would think if you hooked it up to a good scanner it should be able to read the soft code that will be stored from the cel coming on.
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #5 of 15 (permalink) Old 06-23-2009, 06:28 PM
member
Images: 19
Are you able to get a fuel pressure reading?? Last fuel filter change??
Just a couple of things I'd check out.. Good luck..
CrawfishPSD is offline
post #6 of 15 (permalink) Old 06-23-2009, 08:47 PM
joebob3093's Avatar
Send a message via Yahoo to joebob3093
mine cuts out in the mornings but not evry morning. it will cut out for a sec then be just fine. replaced the oil and it made it alot better but didnt solve all the problem. hooked it up to AE and couldnt pull any codes. im drawing a blank to what it could be.
{95 F250 Powerstroke XLT} 5 spd, Wildman 6 pos. chip, custom IC, ADs, AFE stage 2 intake, 3" down pipe to custom 5in stack. EBPV break, shimed FPR, idm mod by mattymx, CCV mod, Leveling Kit, diprocol egt and boost guages.
joebob3093 is offline
post #7 of 15 (permalink) Old 06-23-2009, 09:16 PM
Images: 11
And mine does it predominantly when the windshield wipers are on.
It's not predictable nor regular, just annoying in it's intermittency.
NGS hasn't showed a thing, but then I haven't had the chance to have the scanner on it when it happens, either.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
Mafia # 27
post #8 of 15 (permalink) Old 06-23-2009, 09:22 PM Thread Starter
will try fuel filter
post #9 of 15 (permalink) Old 06-24-2009, 12:34 AM
F350-6's Avatar
Doesn't show any codes at all, or just no codes out of the normal? Chaffed wires in the main engine wiring harness will throw a P0603 code since it causes the PCM to reset (hence the hesitation or stall). Not to be confused with the P0603 from a tuner.
Likewise a P1211 can indicate an ICP or IPR issue instead of the normal tuner related code. Check the main engine wiring harness and IPR harness for chaffed or burnt wires.
For the issues with the windshield wipers, I've heard about issues with the wipers on intermittent interfering with the CPS signal. Maybe check the CPS wiring, add some di-electric grease to the connector, or just try a different setting on the wipers.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 380,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350-6 is offline
post #10 of 15 (permalink) Old 06-24-2009, 12:37 AM
joebob3093's Avatar
mine just has normal codes that i had before this started happening
A/C Cuts Out kruser02 General Ford Truck and Excursion 3 07-06-2009 04:25 AM
Engine Cutting out while driving. shamrock13 1994-2003 7.3L Power Stroke 6 03-29-2009 03:44 AM
How long do you let your engine warm up before driving off after a cold start jethrow 2003-2007 6.0L Power Stroke 8 02-16-2008 06:32 PM
Engine speed drops to idle while driving! barnbridge 2003-2007 6.0L Power Stroke 1 05-07-2007 04:39 AM
