Front hub bearings.... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by biz, this thread has received 28 replies and been viewed 2684 times.
post #1 of 29 (permalink) Old 06-26-2009, 10:20 PM Thread Starter
biz
anyone have good luck with the new hub bearings sold on ebay?
they are much less expensive then ones from auto parts stores or the dealership.
Im wondering how the quality is.
2000 F-350 Super cab, Tadds tunes, AFE Pro Guard intake, 4" MBRP cool Duals, Nexus Gauges , Tubonetics Ball Bearing Turbo.
biz is offline
post #2 of 29 (permalink) Old 06-26-2009, 10:57 PM
I prefer to have my front wheels (rear wheels too, actually...) firmly attached to the truck so that's why I went with ONE OF THESE instead of an Ebay front hub.
jvencius is offline
post #3 of 29 (permalink) Old 06-26-2009, 11:03 PM Thread Starter
biz
yea im not gonna spend $2,000.00 on that setup...... as tempting as it is....
biz is offline
post #4 of 29 (permalink) Old 06-26-2009, 11:08 PM
TDG MAFIA #101
tm0231009's Avatar
I bought one of the ebay ones, because I was needing some in a hurry and I was almost broke so this was the only option that I took inot consideration. Knock on wood, but I haven't had any trouble with mine. The only thing I noticed that concerned me was after installation there was some very slight play in the tire when a pry bar was used to check. But, everything seems to be doing fine. I would actually suggest doing what jvencius did, but I also know how money gives some people problems. So I guess my experience talking would say that they are a quick fix that will do you some good, but I'm sure that they will not hold together as long as the good ones, you get what you pay for. Hope this helps.
P.S. I think I've got 20-25,000 miles on these so I don't know how long they will last.
On the hunt for a 7.3 preferably CC or Ext. Cab SB...Let me know of any deals.
1979 Ford F-100 Ranger, Custom dark purple and silver paint, 15"x8"117 Series Eagle Alloy's, Winston tires, 400 cu - Work In Progress!! http://www.cardomain.com/ride/2570291
"The only dumb question is the one not asked."
TDG MAFIA MEMBER #101
TDG SINGLES CLUB MEMBER #88
tm0231009 is offline
post #5 of 29 (permalink) Old 06-26-2009, 11:14 PM
brendonv's Avatar
I'm thinking about that actually. I heard the early 99' hub bearings where like $500 a peice. Plus one of my stock hubs is tight, so it'd prob end up costing the same in the end.
Early 1999 F350 DRW Dump, 6spd 4x4, 4" Turbo Back and DIY Intake
Early 1999 F350 SRW 8' Box, 6spd 4x4 Stock
brendonv is offline
post #6 of 29 (permalink) Old 06-26-2009, 11:19 PM
THIS ARTICLE I WROTE got buried but towards the end I wrote about the costs and how I justified the expense before buying the kit.
jvencius is offline
post #7 of 29 (permalink) Old 06-26-2009, 11:26 PM
brendonv's Avatar
Does it work on an early 99? From what I hear the early 99 brake rotors are different than a late 99 and up.
brendonv is offline
post #8 of 29 (permalink) Old 06-26-2009, 11:39 PM
IIRC you'd have to switch out to the late '99 rotors but they would be a minor amount of $$$$ compared to the cost of the whole conversion.
jvencius is offline
The Following User Says Thank You to jvencius For this addition to TDG:
brendonv (06-27-2009)
post #9 of 29 (permalink) Old 06-26-2009, 11:54 PM
TDG MAFIA #101
tm0231009's Avatar
Agreed
The Following User Says Thank You to tm0231009 For this addition to TDG:
post #10 of 29 (permalink) Old 06-27-2009, 03:32 PM
myf350's Avatar
I have an early 99. Just did both wheel bearings. Yes the early 99's are around 500. I just told them I needed bearings for a 00 or 01 and got rotors to matchthe bearings. That's all you need to do.The flange where your wheel studs go thu is 10mm thick on the early 99 and 13mm thick on late 99 & up. 3mm off set is the difference. If you mismatch the rotors and bearings the rotor will hit the caliper bracket due the the difference in offsets.
SOLD...early 99 F350 CC 4WD SRW, Tymar intake, 4 in. turbo back straight pipe w/ 5 in. tip, DP tuner, 203 t-stat, Timbrens in the rear, front leveled, King Ranch wheels, ISSPro gauges, Weston brush guard, rebuilt my trans using a Torqueshift converter
08 CC LB DRW MT 4WD Ranch Hand bumpers...stock for now
myf350 is offline
Front Wheel Bearings rsjohnsn General Ford Truck and Excursion 14 03-14-2008 01:08 AM
mack front wheel bearings. Chris88 Medium and Heavy Duty 5 12-28-2007 05:28 AM
Front Hub Bearings CumminsBlckSmk 5.9L Cummins (1998.5-2002) 8 07-06-2007 05:52 PM
hub bearings? imported_ryan 1994-2003 7.3L Power Stroke 13 07-01-2007 06:23 AM
Need Bearings i.e. Front End Noise Mad Dog Cycles General Dodge Discussion 1 03-23-2007 01:22 AM
