trailer connector - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Woody303, this thread has received 8 replies and been viewed 1511 times.
post #1 of 9 (permalink) Old 06-27-2009, 12:22 AM Thread Starter
trailer connector
I'm in need of a new 7 pin trailer connector. I went to the dealership, and they are asking just under $200 for it. I don't have a Napa nearby, and I won't buy the Asian made junk from Autozone.
Does anybody have a suggestion?
Thanks,
Woody
2001 F-350 Supercab 4x4 Lariat
Real man's trans
ATS exhaust
Gauges
DIY Intake
Tinted Windows
33" Toyo mudders
Captain's Chairs
Woody303 is offline
post #2 of 9 (permalink) Old 06-27-2009, 01:23 AM
Mod Friendly Title
Zaairman's Avatar
www.etrailer.com. Look on their for the wiring kit, its like $20 and plugs right in.
ETA: http://www.etrailer.com/pc-VWH~118243.htm
Damn, they jacked the price of that way up in 2 years...
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
The Following User Says Thank You to Zaairman For this addition to TDG:
Woody303 (06-27-2009)
post #3 of 9 (permalink) Old 06-27-2009, 02:49 AM Thread Starter
Got it, thanks.
Real man's trans
ATS exhaust
Gauges
DIY Intake
Tinted Windows
33" Toyo mudders
Captain's Chairs
Woody303 is offline
post #4 of 9 (permalink) Old 06-30-2009, 12:34 AM
Racer X's Avatar
If not in hand or on the way:
Some RV dealers carry ends and high quality encased wiring. All 7 wires are available inside hard insulation to make any harness needed without using 7 individual wires. You should see examples of the hard full insulated type used on most fifth wheel RV's. Other sources for higher quality 7 wire supplies are horse trailer builders or dealers.
Tip: Eventually the weather boot fails on the O.E.M. bumper connector. It will cross circuit & cause odd electrical problems that just disappear. Until the next heavy rain or mud puddle allows enough water in to cause it again. Ghosts?...nope.
POWERFLOW BY RACER X on Video. Featuring Ford's 7.3L Powerstroke Diesel with custom E4OD Transmission. Powered by custom twin turbo chargers and custom fuel system injecting 473 + cc's of diesel & nitrous @ 800 r.w.h.p!
Racer X is offline
The Following User Says Thank You to Racer X For this addition to TDG:
Woody303 (07-02-2009)
post #5 of 9 (permalink) Old 07-02-2009, 12:51 AM Thread Starter
The other day I noticed that one of the wires going into the back of the connector has come loose. It is also green with corrosion. (obviously been bad for quite some time) I'm also thinking that there is a good possibility that this has been the cause of my electrical problems.
I've ordered one from etrailer.com, and it should arrive in another day or so. I'll report back and let yall know if this helps my ghosts.
Woody
Real man's trans
ATS exhaust
Gauges
DIY Intake
Tinted Windows
33" Toyo mudders
Captain's Chairs
Woody303 is offline
The Following User Says Thank You to Woody303 For this addition to TDG:
Racer X (07-04-2009)
post #6 of 9 (permalink) Old 07-04-2009, 07:29 PM
If you need to replace the plug may want to look at the following solution for a 7 pin connector.
http://www.ezconnector.com/
It's a cool idea but my 5th Wheel has a 9 pin, the horse trailers have 7 pins and the other trailers have 6 or 4 pins. So I just run a 9 pin connector with adapters.
TWHRanch is offline
post #7 of 9 (permalink) Old 07-04-2009, 07:39 PM
This is another site for odds and ends for trailer and hitch parts.
http://www.mrtrailer.com/
He has some stuff I have not seen at any other site or place.
TWHRanch is offline
post #8 of 9 (permalink) Old 07-04-2009, 08:04 PM Thread Starter
Update:
I ordered the part from etrailer.com, and the new harness showed up in the mail the other day. It only took me about 20 minutes to install it. Most of that time was spent getting back up off the ground to grab the next part or another tool. (I'm not 18 years old anymore.) The new parts are a perfect fit, and seem to be of excellent quality. I used a large glob of dielectric grease in each of the connections to help prevent future corrosion.
I took the old part back into the house with me, and put the DVM on each of the pins. One of the wires had a very high resistance, and the rest were okay. Oh, and the broken wire didn't get a reading. duh!! I'm not sure if this harness is/was contributing to the remainder of the electrical problems I've been having, but one can be optimistic.
I won't be hooking the camper up to the truck for about two months, so I won't be able to check things out until then.
Woody
Real man's trans
ATS exhaust
Gauges
DIY Intake
Tinted Windows
33" Toyo mudders
Captain's Chairs
Woody303 is offline
post #9 of 9 (permalink) Old 07-05-2009, 12:19 PM
Dieselis' Maximus
driximus's Avatar
Good deal, Ill have to look at checking mine when i get back.
"Why in hell can't the Army do it if
the Marines can. They are the same
kind of men; why can't they be like
Marines."
Gen. John J "Black Jack" Pershing, USA; 12 February
1918
driximus is offline
7 pin connector in truck bed Silver 6.7 6.7L Cummins (2007.5-2011) 6 04-07-2008 04:56 AM
Connector for alt. OBS GilroyRacing 1994-2003 7.3L Power Stroke 4 01-03-2008 03:54 AM
T-connector Rich 6.7L Cummins (2007.5-2011) 1 12-11-2007 02:36 AM
PCM connector for 6.0 Excursion? bswanzek 2003-2007 6.0L Power Stroke 2 11-22-2007 02:33 AM
7 pin connector ? youngPSD 1994-2003 7.3L Power Stroke 8 08-06-2007 10:46 PM
