7.3 died tonight. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Stevie Mac, this thread has received 7 replies and been viewed 1249 times.
post #1 of 8 (permalink) Old 06-29-2009, 03:48 AM Thread Starter
7.3 died tonight.
So I just changed CPS and it stopped cutting out while driving. Thought I got it fixed.
Tonight after about 250 mile run today half of it pulling a small runabout boat. Like a 16 ft with outboard. So no heavy loads.
The truck died. Would start but run for about 5 seconds and then done.
I can hear the fuel pump. If its the fuel pump, where is it and how much is it gonna cost me?
Plan on fuel filter tomorrow.
So what next.
Stevie Mac is offline
post #2 of 8 (permalink) Old 06-29-2009, 03:54 AM
beware the dark side
fuel pump is under the driver side door mounted on the inside of the frame rail. I would try to get a fuel pressure gauge hooked up to the truck and check the fuel pressure. I have heard others on here state similar problems and find out that the fuel pump could not maintain enough pressure to keep the truck running after it starts.
2003 F-350 XLT 7.3L 4X4 Crew Cab, 3.73, Custom built 4R100, AFE intake, Turbonetics BB Turbo W/1.0 A/R exhaust housing, 238/100% Hybrids from Jim @ Rosewood, 5 inch exhaust w/ 6 inch stacks, Tuned my Matt @ Gearhead, Autometer colbalt gauges, Custom built traction bars, viair dual compressor onboard air system. Mickey Thompson Classic II Rims with 315/75R16 BF Mud Terrains, and 4 inch Rough Country lift kit
New Truck: 2000 F-450 XL 7.3L Standard Cab, 6 Speed Stock for now
Trailers: 1999 Jayco 30' 5th wheel
2004 Wells Cargo 20' enclosed trailer (portable shop)
Its not how fast you get there but how much you can pull on the way there.
vader's fury is offline
post #3 of 8 (permalink) Old 06-30-2009, 02:30 PM Thread Starter
Changed fuel filter. It helped but no fix. It will now idle. But does not run when on the gas.
Guess I need to try fuel pump. Anyhthing else I should try prior to fuel pump?
post #4 of 8 (permalink) Old 06-30-2009, 09:15 PM
TDG MAFIA MEMBER #77
TooLoudTooBad's Avatar
I know this is going to sound odd, but when is the last time the oil was changed and is it up to snuff on the stick? Oil pressure drives the injectors...low oil or no oil = no pressure to the injectors.
TooLoudTooBad is offline
post #5 of 8 (permalink) Old 06-30-2009, 09:26 PM Thread Starter
Will check it out.
Thanks for the tip
post #6 of 8 (permalink) Old 06-30-2009, 09:38 PM
joebob3093's Avatar
Send a message via Yahoo to joebob3093
if you end up with a new fuel pump skip the factory pump and get a walbro
{95 F250 Powerstroke XLT} 5 spd, Wildman 6 pos. chip, custom IC, ADs, AFE stage 2 intake, 3" down pipe to custom 5in stack. EBPV break, shimed FPR, idm mod by mattymx, CCV mod, Leveling Kit, diprocol egt and boost guages.
joebob3093 is offline
post #7 of 8 (permalink) Old 07-01-2009, 02:17 PM Thread Starter
Checked oil, 2 quarts low.
Truck is running fine at this point.
New fuel filter and topping off the oil seemed to help out for now.
Thanks again.
post #8 of 8 (permalink) Old 07-01-2009, 02:37 PM
plainredtruck's Avatar
Images: 11
Two quarts shouldn't make enough of a difference in how it runs unless you're having oil supply issues elsewhere - HPOP or LPOP (doubtful on the LPOP, though).
I would check wiring connections to the fuel pump as well as the actual output.
1. Place clean catch basin under fuel bowl drain.
2. Open fuel bowl drain.
3. Turn key on and allow to run for 30 seconds.
4. Turn key off and close fuel bowl drain.
5. Measure amount of fuel in catch basin.
6. Hope somebody posts up the amount you should be able to measure because I can't find the flow rate right now
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
Truck Died tonight, need help please. coolinthewoods 2003-2007 6.0L Power Stroke 9 03-21-2009 04:37 AM
6.5 died again imported_Prodiesel 6.5L Diesel Engine 8 11-24-2007 01:41 AM
Truck died tonight !!!!!! 01blkf250 1994-2003 7.3L Power Stroke 27 06-26-2007 03:47 AM
Possible ECM died now.. 02sprtcumns 5.9L Cummins (1998.5-2002) 2 01-15-2007 12:07 AM
96 PSD died Slacker 1994-2003 7.3L Power Stroke 9 06-05-2006 01:50 AM
