pulling the fan clutch - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by f250_kinda_girl, this thread has received 7 replies and been viewed 1331 times.
post #1 of 8 (permalink) Old 07-01-2009, 08:17 AM Thread Starter
hey all, thanks in advance for any help!
so the boyfriends water pump went out, and we are having an issue getting the fan clutch off. the wrench kit comes with a 40 mm and a 48 mm wrench, but the 40 is to small, and the 48 is too big. Any idea on what the size we need is?
1994 7.3 direct injected turbo (vin code f)
f250_kinda_girl is offline
post #2 of 8 (permalink) Old 07-01-2009, 01:43 PM
Get one of THESE and you're problem's solved...
jvencius is offline
post #3 of 8 (permalink) Old 07-01-2009, 02:14 PM
Dually Club #3
jdydiesel's Avatar
Please don't use a pipe wrench on somethinglike that. They are designed for PIPE. If you don't want to buy the right size wrench then buy a 15" or 18" adjustable wrench. I have what i call a FORD wrench (Navy term). It is an adjustable wrench but the jaws are 90 degrees to the handle and the jaws open real wide. Either one of these options will work for you.
Jason
72 F-250 Gasser.FOR SALE
jdydiesel is offline
The Following User Says Thank You to jdydiesel For this addition to TDG:
plainredtruck (07-01-2009)
post #4 of 8 (permalink) Old 07-01-2009, 04:09 PM Thread Starter
but what is the right size? thats the question
post #5 of 8 (permalink) Old 07-01-2009, 04:28 PM
PSD trainee
Post
I changed the waterpump on my 6.0 the 1st month I had it (last Dec.). Anyway I went down to the local Harbor Freight and bought an 18 & 24 inch adjustable. I used the 18" but I had to unbolt the stator shroud for the fan to get at the shaft. My water pump hub had a hole to stick a big screw driver thru to hold it from turning. This was my "welcome to Ford Diesels" initiation and it was a learning experience. In only 6 short months, I also learned about the fabulous oil cooler design, EGR cooling design and the need for the coolant system filter that Ford skillfully neglected to "design in". I think this is why the water pump was on the way out when I bought it with 102K on the odometer.
GL!
GotPSDTorque is offline
post #6 of 8 (permalink) Old 07-02-2009, 01:54 PM
TDG MAFIA MEMBER #77
TooLoudTooBad's Avatar
You can rent one from some NAPA stores or maybe even Autozone. I had to buy mine but don't recall what size it is.
TooLoudTooBad is offline
post #7 of 8 (permalink) Old 07-11-2009, 04:49 AM
Dually Club #3
jdydiesel's Avatar
I don't know the exact size of the flats on the shaft that you need to get to. I don't have any wrench that big. So that's why I used an adjustable wrench. Just buy an 18" adjustable and you will be fine. You will need it again on the truck so it will not be a waste of money.
Jason
post #8 of 8 (permalink) Old 07-11-2009, 08:24 PM
The Irishman
Caos56's Avatar
If your just replacing it, i used an air chisel on the edge of the nut to get it started, but i was also replacing the water pump. it may destroy the water pump bearings. On my biddies we just used a piece of 1/4 in steel and ground our selves a wrench. over all BE CAREFUL!!!
97 F-250 4x4 4Dr Short Bed Tourmaline Green
New HPOP,1.0 Exhaust Housing,
7.3L IC W/ Banks Piping
Straight Piped 5in Grand Rocks,
IDM Mod, 10K Mod, New Body Mounts.
Finally Own!!!!!!!
91 C-350 Four Door Bronco
Billy O'Bryan
Caos56 is offline
Upgraded Clutch Fork w/South Bend Clutch??? Stinger23 1994-2003 7.3L Power Stroke 5 09-07-2010 11:50 PM
Build a pulling truck or pulling tractor? SOOTBANDIT The Polling Place 24 02-25-2009 05:54 PM
MAYBE pulling the cab...? 6L strokin 2003-2007 6.0L Power Stroke 0 02-07-2008 06:56 PM
My 04 pulling fuzzys69 Sled Pulling 5 06-24-2007 05:09 PM
?? about pulling BigWhite250 Sled Pulling 6 01-16-2006 12:24 AM
