check ball location help please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by clay, this thread has received 6 replies and been viewed 6651 times.
post #1 of 7 (permalink) Old 07-02-2009, 04:59 PM Thread Starter
i need to find out the location of the four check balls that go in side the transmission in the valve body they fell out when i was takeing the valve bodys off thanks alot
clay is offline
post #2 of 7 (permalink) Old 07-02-2009, 08:22 PM
myf350's Avatar
I believe there is supposed to be 8 check balls.
SOLD...early 99 F350 CC 4WD SRW, Tymar intake, 4 in. turbo back straight pipe w/ 5 in. tip, DP tuner, 203 t-stat, Timbrens in the rear, front leveled, King Ranch wheels, ISSPro gauges, Weston brush guard, rebuilt my trans using a Torqueshift converter
08 CC LB DRW MT 4WD Ranch Hand bumpers...stock for now
myf350 is offline
post #3 of 7 (permalink) Old 07-02-2009, 08:34 PM
myf350's Avatar
Took this pick out of the rebuild manual I used when I rebuilt my trans, hope it helps.
Name:	4R100 check balls.jpg
myf350 is offline
post #4 of 7 (permalink) Old 07-02-2009, 08:50 PM Thread Starter
i only have 4 that fell 2 are 1/4 and the other 2 are 5/16 thanks for the info
clay is offline
post #5 of 7 (permalink) Old 07-02-2009, 08:55 PM
myf350's Avatar
I am looking in the book right now, but don't see them. I'll keep looking and let you know if I find it.
myf350 is offline
post #6 of 7 (permalink) Old 07-02-2009, 09:00 PM
myf350's Avatar
Found it!
Name:	4R100 check balls 001.jpg
myf350 is offline
post #7 of 7 (permalink) Old 07-02-2009, 09:45 PM Thread Starter
that is what i needed thanks alot
clay is offline
Fuel Line Check Valve Location... MrDanB 7.3L and 6.9 IDI (Pre 1994) 2 03-30-2009 12:46 AM
Location of the KDP blackcloudCTD95 5.9L Cummins 12 Valve (1994-1998.5) 1 02-28-2008 02:42 AM
Check ball 01quadcab 5.9L Cummins (1998.5-2002) 8 10-26-2007 04:23 PM
PCM location diesel_ram_man 1994-2003 7.3L Power Stroke 5 03-04-2007 12:53 AM
IDm Location bubba1541 1994-2003 7.3L Power Stroke 1 10-28-2006 09:05 PM
