help please 16yr old wont start - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 96 f-250, this thread has received 11 replies and been viewed 3916 times.
post #1 of 12 (permalink) Old 07-08-2009, 05:36 PM Thread Starter
hello, i have owned this truck for about 3 weeks its a 1996 f-250 powerstroke with 153k on it i was told all parts are original. the truck is in excellent condition with only a few very minor dents and a small dime sized bit of surface rust at the wheel well. this truck has been babied. so it came to me as a surprize when last week it didnt start my buddy was messing with it and was pushing on the gas and flooded her. i just had to try every couple of hours and then just allowed extra time for the wts light to go out and wait for about 1min and a half and she fired up. so a couple days ago a was rlly stupid and i left the radio on i thought i had ran down the batteries so we charged them still didnt even turn over tried to jump it same story. so i ran down to the auto parts store and picked up a new solenoid same thing just click. then i had remembered this swith i had found on the drivers side beneath the back seat i switched it up and it turned over fine now from the countless atempts to start the truck my dad and i believe its flooded because it will turn over and not fire up i would apreciate any help at all i am only 16 so this is a very stressful situation also could this be the glow plugs or injectors remember both me and my dad are 100% new to diesel so i really need some advice from you guys you know what your talking about thanks
96 f-250 is offline
post #2 of 12 (permalink) Old 07-08-2009, 05:40 PM
Well to ease you up. Its not flooded
Do a couple things first watch your tach while cranking. See if it moves if it doesn't move most likely the CPS is shot. No big deal, $25, 10mm wrench and its fixed. (I'll bet that is your culprit)
If thats not it
Next check your oil level, check your fuel bowl(see if there is fuel in it)
[CENTER]1995 PowerStroke 4x4 - 1968 Bronco
#27
Big Stroker is offline
post #3 of 12 (permalink) Old 07-09-2009, 04:04 AM
pontiacross's Avatar
yep it deffinatly isn't flooded.
dose it smoke at all while cranking?
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #4 of 12 (permalink) Old 07-09-2009, 04:57 AM Thread Starter
it did the first time a few weeks ago but water was on the turbo
and thanks alot it rlly helps im new to the whole diesel thing
96 f-250 is offline
post #5 of 12 (permalink) Old 07-09-2009, 05:04 AM
08powersmoke's Avatar
what? how did water get on the turbo? check for fuel pressure after you do what the other guys told you to check... only a couple reason why a diesel won't start. and 99% of the time its no fuel.
2008 f250 4x4, auto, 3.73
spartan tuned..
37x13.50r20 interco ssm16
pioneer z3 navi, and a few other ear goodies...
B.O.M.B SQUAD #20
RIDING DIRTY CLUB #35
RIDIN' HIGH #23
SINGLES CLUB #199
08powersmoke is offline
post #6 of 12 (permalink) Old 07-09-2009, 05:09 AM
I am confused about the water thing too. do you get smoke out the exhaust while cranking it now. no smoke means it isn't injecting fuel. could mean no fuel pressure, no oil pressure , or somthing electronicly...
Ross
Tow Rig
The Following User Says Thank You to pontiacross For this addition to TDG:
08powersmoke (07-09-2009)
post #7 of 12 (permalink) Old 07-09-2009, 05:35 PM
dmd
dmd's Avatar
96 F250 - Please use some punctuation. Your messages are very difficult to read.
You need to figure out what that switch is connected to.
Like other have said, a "flooded" diesel will blow white smoke out the tail pipe. If
no start and getting white smoke the there is an glow plug issue. If cranking
and no hint of white smoke then there is no fuel.
If no smoke, pop open the fuel bowl, it should be full... If not you could just be out of fuel, of have a intank or fuel pump issue.
2k, F350 SuperCruzer, 7.3L Diesel, Auto trans, 4x4, Tony Wildman 6-pos chip, Custom 4-inch intake, 4-inch turbo-back exhaust, ATS housing, Adrenaline HPOP, BTS Trans, EBPV delete, ITP overboost eliminator, in-tank and pre-pump mod, Heater valve mod
dmd is offline
post #8 of 12 (permalink) Old 07-09-2009, 06:31 PM
Mod Friendly Title
Zaairman's Avatar
Its summer and he's in Ohio. Should be plenty warm there to start without the glow plugs...
First thing I'd do is the CPS.
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #9 of 12 (permalink) Old 07-09-2009, 08:13 PM
TDG MAFIA MEMBER #77
TooLoudTooBad's Avatar
The batteries or starter may be on their way out also. If you don't have enough cold cranking amps coming from the batteries, the truck will not start. Take the batteries in and get them tested beofre forking over good money on new ones.
Post up and let us know what you have found out.
TooLoudTooBad is offline
post #10 of 12 (permalink) Old 07-09-2009, 08:30 PM
myf350's Avatar
where in Ohio are you?
SOLD...early 99 F350 CC 4WD SRW, Tymar intake, 4 in. turbo back straight pipe w/ 5 in. tip, DP tuner, 203 t-stat, Timbrens in the rear, front leveled, King Ranch wheels, ISSPro gauges, Weston brush guard, rebuilt my trans using a Torqueshift converter
08 CC LB DRW MT 4WD Ranch Hand bumpers...stock for now
myf350 is offline
Tags
diesel, powerstroke, truck help, wont start
just wont start rock_meg 2003-2007 6.0L Power Stroke 21 01-15-2009 04:47 AM
wont start doob51 5.9L Cummins 12 Valve (1994-1998.5) 3 05-06-2007 02:05 PM
05 wont start twin_turbocummins05 5.9L Cummins (2003-2007.5) 11 04-21-2006 09:27 PM
