What else to do!?!? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rollincoal97, this thread has received 5 replies and been viewed 935 times.
post #1 of 6 (permalink) Old 07-08-2009, 09:27 PM Thread Starter
rollincoal97's Avatar
What else to do!?!?
MY 96 powerstroke is havin a major issue with the motor.I can start it fine and start driving and its like once its warmed up after a few miles it will miss once,then a couple seconds later again,and worse and worse til its like its starving for fuel and running realy rough.If i turn it off then for a bit and back on,It runs fine for a couple miles or so then starts doing the SAME thing.The cam sensor is fine,checked that.Tried unhooking the DP tuner,same problem.Tried a different computer from a loaner truck,same thing.Could it possibly be a oil pump issue? It has a new bosch pump that has about 6,000 miles on it now.It has an aftermarket fuel system but the gauge shows the fuel pressure never changes either. Are there any other electrical or timing issues i could check? Im at a loss and dont know what to do anymore!
2001 dodge cummins 24v automatic daily driver, quad cab long box, sport/slt package, AFE stage 2 intake, stock exhaust straight piped, EDGE Comp box, fass fuel pump, plugged wastegate, 33x12.5x17 PRO COMP tires and rims
rollincoal97 is offline
post #2 of 6 (permalink) Old 07-08-2009, 10:10 PM
When was the last time you changed the fuel filter(s)?
jvencius is offline
post #3 of 6 (permalink) Old 07-08-2009, 11:15 PM Thread Starter
Well this happened to me a couple months ago,so i changed em and it went away.That was only a few hundred miles ago though.So i drained them and it looked fine,no water or anything.And not forgetting the fact they are only a couple hundred miles old.And another thing,my fuel pressure hasnt changed,even when it acts up.It also blows white smoke sometimes which means unbearned fuel.I had a guy hook up a scanner and it says all the injectors are working but is there still a chance they aren't pumping correctly or something? This is my first diesel and im only 20 years old so a lot of this stuff is new and im trying to learn as i go.
post #4 of 6 (permalink) Old 07-09-2009, 01:53 AM
rock removal technition
check your valve cover gaskets and harnesses
double-s-diesel is offline
post #5 of 6 (permalink) Old 07-09-2009, 03:50 AM Thread Starter
Harnesses all seem to be in great shape.I dont know about the gaskets at all
post #6 of 6 (permalink) Old 07-09-2009, 04:01 AM
pontiacross's Avatar
have you checked for codes?
I agree with him, pull your valve covers off and look at the injector harness under there.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
