tranny clunking when you put in gear?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Kip, this thread has received 5 replies and been viewed 1749 times.
post #1 of 6 (permalink) Old 07-09-2009, 01:49 PM Thread Starter
Kip
In the passing lane
Kip's Avatar
like it say my tranny clunks really bad when I put it in Drive or if I move it up to reverse it does it but not as loud. It also vibrates a little bit driving down the road but I think that because I just got the tires balance and they most be off I bit. So any ideas Please.
oh yeah it drives fine once its in gear
2005 2500HD DIRTYMAX 6in lift, dual exhaust, afe airbox. Tuner soon to come
2001 PSD shortbed crewcab, ATS tranny edge juice w/attitude, Superchips programmer, Gauges, exhaust, 4inch lift w/35s, (SOLD)
Originally Posted by sledneck57
Your sweating like a queer holding a hot dog.lol.
Kip is offline
post #2 of 6 (permalink) Old 07-09-2009, 02:07 PM
Your slip joint in the driveshaft may need greasing--they dry out and don't have any zerks for routine servicing...
jvencius is offline
The Following User Says Thank You to jvencius For this addition to TDG:
Kip (07-09-2009)
post #3 of 6 (permalink) Old 07-09-2009, 02:08 PM
buffalobob's Avatar
might check the u jointd in driveshaft
2011 silverado lt, crewcab, short bed, 4X4, d-max/ allison
buffalobob is offline
The Following User Says Thank You to buffalobob For this addition to TDG:
Kip (07-09-2009)
post #4 of 6 (permalink) Old 07-09-2009, 05:27 PM
dmd
dmd's Avatar
Check from the spindle out of the trans, all the way back to the rear-end. Not just
a specific spindle or u-joint..
The spindle at the trans will usually cause a clunk feel when accelerating.
If you hold the brake and move back and forth from drive to reverse does it
keep clunking? If so it is most likely a u-joint. Could be anything from
the trans back though. Could even be the trans...
2k, F350 SuperCruzer, 7.3L Diesel, Auto trans, 4x4, Tony Wildman 6-pos chip, Custom 4-inch intake, 4-inch turbo-back exhaust, ATS housing, Adrenaline HPOP, BTS Trans, EBPV delete, ITP overboost eliminator, in-tank and pre-pump mod, Heater valve mod
dmd is offline
post #5 of 6 (permalink) Old 07-10-2009, 10:43 PM Thread Starter
Kip
In the passing lane
Kip's Avatar
yes if I got back and forth it does it both reverse and drive I hope its just u-joints
Kip is offline
post #6 of 6 (permalink) Old 07-11-2009, 08:26 PM
The Irishman
Caos56's Avatar
U-Joints
happened to the neighbors 02 F250
Possibly a carrier if you have one? I do on both of mine
97 Heavy Duty
05 Super Duty
97 F-250 4x4 4Dr Short Bed Tourmaline Green
New HPOP,1.0 Exhaust Housing,
7.3L IC W/ Banks Piping
Straight Piped 5in Grand Rocks,
IDM Mod, 10K Mod, New Body Mounts.
Finally Own!!!!!!!
91 C-350 Four Door Bronco
Billy O'Bryan
Caos56 is offline
6+1 tranny, gear ratios? OD? imported_johndear720 Medium and Heavy Duty 5 02-17-2008 11:03 PM
Tranny 1st to 2nd gear lukesdiesel 5.9L Cummins (1998.5-2002) 4 03-26-2007 06:15 PM
tranny seems to hunt for a gear moboy 5.9L Cummins (1998.5-2002) 5 03-23-2007 02:24 PM
Tranny falls out of gear? DmaxRig Duramax 2001-2004 (LB7) 4 06-19-2006 08:52 PM
Tranny Hammer'n 2nd Gear KillerQuad 1994-2003 7.3L Power Stroke 16 12-03-2005 04:38 PM
