dt466 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by balz out, this thread has received 5 replies and been viewed 1809 times.
post #1 of 6 (permalink) Old 07-12-2009, 02:36 AM Thread Starter
balz out's Avatar
dt466
so i heard about international dt 466 turbos being dropped into a f350 with minimal mods... has anybody on here heard of it and what has to be done? i have a donor dump truck at work that i would love to take the turbo off of. thanks
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
post #2 of 6 (permalink) Old 07-12-2009, 02:40 AM
Define "minimal"--to some folks that means no-tools, to others it means only a little welding is involved...
jvencius is offline
post #3 of 6 (permalink) Old 07-12-2009, 03:00 AM Thread Starter
balz out's Avatar
not exactly a bolt on but nothing to serious like complete custom fab. i am confident in my welding its just that i am not a big fabricator
balz out is offline
post #4 of 6 (permalink) Old 07-12-2009, 10:47 PM
pontiacross's Avatar
it would take some major fabrication for not much gain in my opinion.
those turbos are supported by the exhaust housing where the 7.3 turbos are supported by the center section. you would need ne up pipes, mount to block, oil feed and drain lines, and a new y-pipe into the intake. if your going to go through all that work go with a H2E or something like that.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #5 of 6 (permalink) Old 07-12-2009, 11:26 PM Thread Starter
balz out's Avatar
i will just slap a wicked wheel or banks wheel in my turbo now and see what that does for me... thanks guys
balz out is offline
post #6 of 6 (permalink) Old 07-13-2009, 12:16 AM
Originally Posted by balz out View Post
i will just slap a wicked wheel or banks wheel in my turbo...
Same thing, different names...
jvencius is offline
Old or New DT466 better? Todd Frampton Medium and Heavy Duty 8 06-25-2011 03:34 PM
Dt466 SMOKIN Medium and Heavy Duty 2 05-24-2007 11:47 PM
DT466 Oil Pan Strokerin Medium and Heavy Duty 3 04-06-2007 05:28 PM
Dt466 circle5 Diesel Conversion 11 02-27-2007 07:46 AM
TS MP-8 for DT466 Tim @ P.I.S. Medium and Heavy Duty 15 10-06-2006 08:57 PM
