HPOP lines - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JoeDirte, this thread has received 5 replies and been viewed 3372 times.
post #1 of 6 (permalink) Old 07-12-2009, 09:10 AM Thread Starter
HPOP lines
Hey guys,
I spotted another leak. It's coming from the HPOP line that leads to the driver side head, not at the HPOP itself. Is there an o-ring there? From what I've read, it seems the o-rings at the HPOP are known for leaking and the kit takes care of that, but there's no mention of what's at the other end of the lines. Any instructions on how to change the o-ring there if it has one?
JoeDirte is offline
post #2 of 6 (permalink) Old 07-12-2009, 10:45 PM
pontiacross's Avatar
what year is your truck, yes there are O-rings but there are to differant stiles of lines so there may be a couple of differant ways to take care of the leak
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #3 of 6 (permalink) Old 07-14-2009, 01:56 AM
sometimes the quick connect fittings leak, replace the line and the fitting that goes into the head if thats what your talking about.
Ford certified diesel tech.
96 F350 reg cab, black. stage Is, exhaust intake TS 6pos chip and a few small tricks. tranny built up a little and a billet converter. 4in lift 35 bfg muds.
3" cowl hood, billet grille, bumper with billet grille and fog lights, 10in drop rear bumper with lights and a dropped hitch.
90 mustang lx 347 afr 185s, vic jr efi, aeromotive fuel system, c4 , 4.10 31 spline, tube k member and control arms coil overs and control arms in the rear, 10pt cage.
05 f250 red ext cab grey int, 4x4 6.0 suncoast tranny, ats 275cc injectors, studs, aeromotive fuel system, turbonetics 70mm ceramic coated turbo, dual 5 inch stacks turnned out. ALL PARTS FOR SALE
fordboyyfm is offline
post #4 of 6 (permalink) Old 07-14-2009, 05:32 AM Thread Starter
I got a 2000. It's leaking at the line from the HPOP at the driver side head. How do you disconnect that to replace the o-ring. I'd rather not replace the line if I don't have to. I'm afraid to even ask how much a new line costs.
JoeDirte is offline
post #5 of 6 (permalink) Old 08-05-2009, 07:05 AM Thread Starter
Let's see if this pic works...
Name:	HPOP package.JPG
2000 F250 Supercab 2wd, 6spd, DP Tuner, Southbend conFE, MBRP 4" turbo back straight pipe. DIY intake.
JoeDirte is offline
post #6 of 6 (permalink) Old 08-05-2009, 07:18 AM Thread Starter
So the pic does work. I didn't feel like paying for the quick disconnect tool and waiting for delivery. I cut one out of a Simpson nail plate. I didn't even try to do the disconnect with the lines connected. I wrenched the fittings off and disconnected the fittings in a vise. The fitting connected to the pump was a pita. I picked up the fittings from the stealership, F81Z-9N332-AA = $12.69, F81Z-9C402-AA = $16.82. Not too bad in price. The fittings with the red o-rings I guess are a newer design.
JoeDirte is offline
A/C lines budtoh3zo 2008-2010 6.4L Power Stroke 16 07-18-2009 06:36 AM
I have foresale a Dj fuel intisier kit with braided lines. All lines and fittings tha Robts Whats Been Sold 3 05-02-2008 12:10 AM
HPOP Lines SICKS-O Whats Been Sold 1 08-17-2007 05:10 PM
custom HPOP lines? SICKS-O 1994-2003 7.3L Power Stroke 8 08-16-2007 07:57 PM
HPOP lines leaking? 91redstang 1994-2003 7.3L Power Stroke 1 04-26-2007 02:33 AM
