Fuse Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by powerstrokin8, this thread has received 3 replies and been viewed 869 times.
post #1 of 4 (permalink) Old 07-13-2009, 02:53 AM Thread Starter
powerstrokin8's Avatar
Fuse Question
I have a 2002 F-250 with the 7.3L. The other day my cruise control wasn't working and i do not have a fuse box diagram. Does any one have one or know which fuse it is or if its one of the fuses under the hood?
powerstrokin8 is offline
post #2 of 4 (permalink) Old 07-13-2009, 05:07 AM
RussK's Avatar
The cruse is controlled by the PCM, but for the PCM to engage the cruise it needs
Fuse #22 20amp brake pressure switch
Fuse # 34 10amp brake on / off switch
Fuse # 45 10amp clutch / clutch jumper if auto
Also check your control switches
2001/05ish f250 Lariat 4x4 automatic, airaid intake, custom paint, 4 tan buckets’ covered in dead cow skin, wood dash & trim,gauges,elc trans cooler,Custom door sill lights (light up ground when door opens) Lots and lots of sound deadening other than that pretty much stock
Mercedes e320 (wife’s)
Nissan Maxima (work driver)
Dodge Magnum (work driver)
Trx 250r (off road adrenalin pump)
FORD 3600 diesel tractor
Singles club #164
american club # 9
I want to die while asleep like my grandfather,
not screaming in terror like the passengers in his car.
Russell
my truck from the begining
http://s391.photobucket.com/albums/o...um/my%20truck/
RussK is offline
post #3 of 4 (permalink) Old 07-13-2009, 06:05 AM
Does the horn work?If not then your clock spring needs to be replaced.Also check the plug on the bottom of the brake res.
kainers is offline
post #4 of 4 (permalink) Old 07-13-2009, 08:37 AM
4play's Avatar
ck fuses mentioned above,
check brake pressure switch on master cyl ( 2-wire switch, red wire is power, black/yellow goes to pcm ) both should have power when plugged in and off brake pedal
check brake pedal position switch ( on brake pedal, light blue/black wire is power, red/light green should only have power when pedal is pressed. i doubt this is you problem or you will have abs concerns, 4wd/low range concerns, wont shift out of park.
last but not least i would suspect the steering wheel switches are the culprit. these deal with resistance values that change with each button that pressed
these circuits do run through the clock spring that also has circuits for the air bag and horn.
4play is offline
Fuse or relay question DHenson 5.9L Cummins (1998.5-2002) 5 03-19-2009 02:28 AM
Fuse Question???? jp39bfd Duramax 2006-2007(LBZ & LLY) 4 02-17-2009 12:16 PM
relay or fuse question?? 4x4??? mvwheeler02 1994-2003 7.3L Power Stroke 2 02-02-2008 11:02 PM
Fuse panel question... Blown306 General Ford Truck and Excursion 1 03-16-2007 12:47 AM
Fuse Question DBogo 1994-2003 7.3L Power Stroke 6 07-04-2006 02:52 AM
