new tranny slipping goin into every gear. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Orangepstroke, this thread has received 8 replies and been viewed 1185 times.
post #1 of 9 (permalink) Old 07-14-2009, 03:33 PM Thread Starter
strokin now cummin later!
Orangepstroke's Avatar
i just installed a brand new suncoast tranny. everything seems to be great except the fact it slips goin into 2,3, and 4. fluid is fine, everything is new.
ive heard that the tps or app could cause it to do this? any ideas?
Erik, 2001 psd 4x4 lariat ext cab pulling truck
Ts 140hp 6pos chip, 100hp split shots, stealth 2 pump,h2e turbo, tranny, afe stage 2,
5" exhaust turbo back, 10" stack, 3.9k mod on a switch, shimmed fpr,hx crossover hose, tc lock up switch. Custom weight rack and ladder bars, f550 springs, custom paint,5%+15% window tint, clear lights,custom billet grille, very big stereo, 20x10 moto meatals wrap with 33x13.50x20 ss iroks
1996 2500 12v 2wd auto reg cab, flat bed, afc mods, sdx 140hp sticks, 4gsk, 60lbs springs, 191dv's, head studs, 16* timing, phat shaft 62/65/14 no plate, exhaust, intake, tanny, auto meter, adjustable overflow valve.
Singles Club #42
Orangepstroke is offline
post #2 of 9 (permalink) Old 07-25-2009, 05:53 PM Thread Starter
bump
Singles Club #42
post #3 of 9 (permalink) Old 07-26-2009, 05:57 PM
RussK's Avatar
was the old trans doing the same before it died? if so you could have somthing causing the new one to shift that way
2001/05ish f250 Lariat 4x4 automatic, airaid intake, custom paint, 4 tan buckets’ covered in dead cow skin, wood dash & trim,gauges,elc trans cooler,Custom door sill lights (light up ground when door opens) Lots and lots of sound deadening other than that pretty much stock
Mercedes e320 (wife’s)
Nissan Maxima (work driver)
Dodge Magnum (work driver)
Trx 250r (off road adrenalin pump)
FORD 3600 diesel tractor
Singles club #164
american club # 9
I want to die while asleep like my grandfather,
not screaming in terror like the passengers in his car.
Russell
my truck from the begining
http://s391.photobucket.com/albums/o...um/my%20truck/
RussK is offline
post #4 of 9 (permalink) Old 07-27-2009, 07:57 AM Thread Starter
it did going into third. second and overdrive just layed she shifts over real bad then hit hard. im sure its realated im just not sure what it is
Singles Club #42
post #5 of 9 (permalink) Old 07-27-2009, 02:15 PM
TDG Mafia #76
John_DeereGreen's Avatar
Pull whatever tuning you've got it out and see if that helps.
Jarrett
04.5 qcsb commonrail
Smarty TnT
John_DeereGreen is offline
post #6 of 9 (permalink) Old 07-27-2009, 05:15 PM
MAFIA MEMBER 106
camojeeper's Avatar
I agree with matt pull the chip then try it
STEVE TDG MAFIA#106
camojeeper is offline
post #7 of 9 (permalink) Old 07-28-2009, 02:32 AM Thread Starter
i did that a few weeks ago. it didnt do it but the truck doesnt have any power what so ever with out a chip installed, it doesnt like the turbo with out the extra fuel.
Singles Club #42
post #8 of 9 (permalink) Old 07-28-2009, 03:19 AM
I Wanna Go Fast!
brentos's Avatar
welp its in the tune apparently. the tranny is built to hold the power so thats not the issue
brentos is offline
post #9 of 9 (permalink) Old 07-28-2009, 04:50 AM
MAFIA MEMBER 106
camojeeper's Avatar
get the dp and be done
STEVE TDG MAFIA#106
tranny slipping sidssm 1994-2003 7.3L Power Stroke 5 10-12-2007 01:29 AM
Slipping Tranny toddsnorthriver 2003-2007 6.0L Power Stroke 3 09-25-2007 03:15 AM
Tranny Slipping???? hummin 600 2003-2007 6.0L Power Stroke 13 06-07-2006 03:31 PM
Tranny slipping bad jroderick 5.9L Cummins (2003-2007.5) 17 05-21-2006 06:24 AM
Tranny Slipping M.R.C. F-250 2003-2007 6.0L Power Stroke 9 11-25-2005 02:12 AM
