p0107 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by michael8840, this thread has received 8 replies and been viewed 5687 times.
post #1 of 9 (permalink) Old 07-15-2009, 03:25 AM Thread Starter
michael8840's Avatar
Unhappy p0107
Hi guys,
I am helping a friend that has a 1998 E-350 and for the last couple of months the check engine light has been on continously
The code is p0107 something about a barometric pressure sensor out of range, but where the hell is this sensor located?????
Also at cold start ups the van smokes white smoke like hell, but he just changed the injector o-rings
When it warms up the smoke completely clears
Thanx guys,
michael
1996 7.3L powerstroke econoline E-350 cargo van
1999 7.3L superduty F-350 crew cab,lb
2003 6.0L powerstroke F-250 crew cab,sb FX4
2006 6.0L powerstroke F-250 crew cab,lb
1992 chevrolet caprice classic (305 cid
1998 mercury grand marquis LS
michael8840 is offline
post #2 of 9 (permalink) Old 07-16-2009, 12:32 AM Thread Starter
NOBODY????
post #3 of 9 (permalink) Old 07-17-2009, 11:11 PM Thread Starter
post #4 of 9 (permalink) Old 07-19-2009, 07:58 PM Thread Starter
can we try to change out the pcm????
thanx
post #5 of 9 (permalink) Old 07-19-2009, 10:09 PM
balz out's Avatar
on the 6.0 that sensor is located below the steering column and hidden behind plastic. i dont know if that is going to help you or not but its worth a shot to change out that sensor before going and doing something more expensive
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
The Following User Says Thank You to balz out For this addition to TDG:
michael8840 (07-19-2009)
post #6 of 9 (permalink) Old 07-19-2009, 10:21 PM
balz out's Avatar
if its a diesel engine in the van you are wrong, that code is for your map sensor circuit low input
balz out is offline
post #7 of 9 (permalink) Old 07-19-2009, 11:59 PM Thread Starter
but in the code description it also says barometric pressure sensor
I will change out the map sensor tomorrow and see what happens
thanks
post #8 of 9 (permalink) Old 07-20-2009, 12:25 AM
balz out's Avatar
map if its diesel of course, pick up the hanes repair book for the super duty/diesel engine book and it will tell you what it means for gas motor or diesel, gas is barometric/manifold pressure and diesel is map sensor low output
balz out is offline
michael8840 (07-20-2009)
post #9 of 9 (permalink) Old 07-20-2009, 12:43 AM Thread Starter
okidoki
