???? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by michael8840, this thread has received 12 replies and been viewed 1216 times.
post #1 of 13 (permalink) Old 07-19-2009, 05:03 PM Thread Starter
michael8840's Avatar
Question ????
Hi guys,
I shimmed my fpr today and at the firt try I got like 125 psi, I tought that was a bit too much so I made the shim a bit smaller but I am still getting like 100-105 psi
I just left it like that for now, but now my question is if it isn't going to hurt anything?????
Thanks for the help guys,
michael
1996 7.3L powerstroke econoline E-350 cargo van
1999 7.3L superduty F-350 crew cab,lb
2003 6.0L powerstroke F-250 crew cab,sb FX4
2006 6.0L powerstroke F-250 crew cab,lb
1992 chevrolet caprice classic (305 cid
1998 mercury grand marquis LS
michael8840 is offline
post #2 of 13 (permalink) Old 07-19-2009, 05:06 PM
Limit to 75 psi or less.
Otherwise, watch your fuel pump die on you in no time.
Plus, plenty of folks have played around with fuel pressures, and not many found any benefit in going beyond 75 psi. Depending on injectors, 60-70 psi seems to be a standard sweet spot, but varies with other mods and type of injectors. Mine runs best between 65-70 psi.
Pocket is offline
The Following User Says Thank You to Pocket For this addition to TDG:
michael8840 (07-19-2009)
post #3 of 13 (permalink) Old 07-19-2009, 05:13 PM Thread Starter
Thanks pocket,
The reason I shimmed the fpr is that my fuel pressure never goes over 45psi
We checked everything, we even lowered the tank and found nothing wrong.
I also cleaned the fuel bowl completely,put in a new filter and a new fuel pump and I still got the 45 psi
I will go and make my shim even smaller
michael
post #4 of 13 (permalink) Old 07-19-2009, 06:05 PM
balz out's Avatar
when i shimmed mine i started at 95 and took me 5 tries to hit 71-72... what are you using to shim it with
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
post #5 of 13 (permalink) Old 07-19-2009, 07:13 PM Thread Starter
I am using a small bolt (I think 5 mm) that I saw a piece off and put it in (I don't owe a bb gun)
post #6 of 13 (permalink) Old 07-19-2009, 11:46 PM
balz out's Avatar
small bolt is way better to use... i took a little screw off of a ball valve and ground it down to fit in the fpr cover. how are your metering your pressure?
balz out is offline
post #7 of 13 (permalink) Old 07-19-2009, 11:56 PM Thread Starter
on the back of the fuel bowl,just above the fuel heater plug, there is a hex bolt (I think they call it like that) that you can remove with an allen wrench
After having removed the plug I installed an 1/4npt x1/4 flare coupling to connect my meter
post #8 of 13 (permalink) Old 07-20-2009, 12:23 AM
balz out's Avatar
there is another spot that is better and will make easy to drain fuel filter also... hook a 5/16 hose thats about 3 foot long to the drain pipe that is passenger side of block, then put a gauge on it and turn truck to on position and open the drain valve to the fuel filter and it will go right to your pressure. take gauge off and tuck hose some where
balz out is offline
post #9 of 13 (permalink) Old 07-20-2009, 12:46 AM Thread Starter
never thought about doing it that way
it sure is a lot easier,the next one will go that way
post #10 of 13 (permalink) Old 07-23-2009, 11:53 PM
fuel pressure gauge
What kind of gauge do you use, where do I get one, and how much are they?
Lord_Zarkon is offline
