is this something that happens often? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bcarriveau, this thread has received 10 replies and been viewed 1556 times.
post #1 of 11 (permalink) Old 07-20-2009, 03:20 AM Thread Starter
********* and Mafia #90
Bcarriveau's Avatar
to the bell housing? this is a 95.. crack starts at the starter and goes all the way up. not sure where it ends.
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #2 of 11 (permalink) Old 07-20-2009, 03:27 AM
pontiacross's Avatar
were all the bolts good and tight?
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #3 of 11 (permalink) Old 07-20-2009, 03:29 AM Thread Starter
Bcarriveau's Avatar
i have not removed this from the truck yet to know, all original and has never been removed.
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #4 of 11 (permalink) Old 07-21-2009, 08:15 PM
CSIPSD's Avatar
I have seen it a few times, more often it comes with a drive line breaking or a front end issue.
CSIPSD is offline
post #5 of 11 (permalink) Old 07-23-2009, 12:06 AM
It can also happen if the housing is really hot and you run through cold water. It might also just be a poor casting which cracked after 14 years of heat cycles.
Slated4Greatness is offline
post #6 of 11 (permalink) Old 07-23-2009, 12:36 AM
TwinStacks
SmknDzl's Avatar
My last trans had the same crack... I just thought I hit something on a jobsite
Chris Cayer- www.facebook.com/SmknDzl or www.myspace.com/smkndzl send a request
Early '99 Black Lariat F-350 cclb dually-TS 6 position, AFE StageII, Autometer UltraLite Gauges, 6" Turnout Stacks, Muffler/Cat Delete, Built Trans from RacerX with .670 Line Mod Valve and Full LockUp Valve, 6.0L Trans Cooler, Boost Relief Valve, Oil X-Over, 5% Tint Around With 20% On The Windshield and 5% Strip On Top, Tinted Tail Lights, 2003 Clear Headlights, VisionX 8K H.I.D. Kit, JVC InDash DVD, APS997 Remote Start and Alarm, Painted Grille and Mirrors, WhiteNight Reverse Lights
Competition Cobra29, DaveMade Comp 2x2, 2x4 and 5pill boxes on VOLTS, Modified Wilson 5000...YEAH IM TALKING
Nathan Airchime P5 Train Horns @ 200PSI
SmknDzl is offline
post #7 of 11 (permalink) Old 07-25-2009, 06:26 AM
If it is a 5 speed and the dual mass flywheel gives up the ghost the vibration may cause the bell housing to crack. I had it happen on a 97 ps diesel
squishy is offline
post #8 of 11 (permalink) Old 07-26-2009, 10:51 AM
Diezel Dawg's Avatar
i had the same thing happen on an 83 Ranger of mine, couldnt keep a starter in it, the crack went right thru the middle of a starter bolt hole. loose bolts and vibration with cause this
Ken
99.5 7.3L PSD 4x4
GTP38R BB TURBO
Casserly 250cc Hybrid injectors
BTS Trans W/ 6.0 Trans cooler
Live Tuned by Jody
TYMAR Intake/Coolant Filter
463hp and 912 tq 6 Feb 10
491hp 944tq 28 Aug 10
Future mods-- AirDog/ITP Reg Ret. Fuel sys. w/fuel bowl del, Terminator Big Oil,
PNWFDE#2
Diezel Dawg is offline
post #9 of 11 (permalink) Old 07-28-2009, 11:08 AM
Bruno2's Avatar
I have a 95 superduty with the disc brakes on the rear . So it has a parking brake on the back of the tranny . These parking brakes have their own fluid in them and people dont monitor the fluid level because it seems that it should be the same fluid thats in the tranny . The one on my 95 locked up and broke the bell housing before I bought it .
Bruno2 is offline
post #10 of 11 (permalink) Old 07-29-2009, 01:14 AM
CSIPSD's Avatar
Huh??? I think you are mistaken... Your parking brakes are at the disks in back... I know, because if I use mine in the winter it freezes up...
CSIPSD is offline
