Truck running Hot?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by woody_1, this thread has received 10 replies and been viewed 1715 times.
post #1 of 11 (permalink) Old 07-22-2009, 04:09 PM Thread Starter
crittergitters.net
woody_1's Avatar
Truck running Hot??
First, I want to thank eveyone for the help when I thought I blew the motor last time.Brian at BTS my hats off to you. I owe you big for staying on the phone and walking me thru everything.#7 injector and I found my IPR was bad and replaced it.
Now I have another issue.It started over flowing coolant out the fill tank on side of radiator.I started by flushing radiator and changing thermostat. I now still have it pressuring up that fill tank and over flowing.It has not ran hot.It will get warmer than normal ,but not Hot.It use to run around the R on the word normal now around the L.This is on the dummy gauge from factory.
Any Ideas what else to check? I also thought it could be a Head gasket is that possible?
I have a 1995 F350 XLT CC 4x4 with,AFE stage 2 cold air intake,3" Down pipe,4" Magnaflow Exhaust,custom Shackles,14"front and 15" back Atlas springs,54"Boggers,20"x14" wheels,2 1/2 ton rockwells w/ 6.72 gears,custom high rise steering,Tranny cooler,Shimmed FPR, gutted EBPV.Autometer gauges with roof mount over mirror.BTS tranny with a PCS trans controller,Stage 2 injectors,Tony's Wildman 6 position chip.Pedal mod.HX hose,Banks intercooler kit.
woody_1 is offline
post #2 of 11 (permalink) Old 07-22-2009, 05:04 PM
balz out's Avatar
water pump and hoses. i used to have a 95 250 and that happened to me, pump was like 225 at parts store
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
post #3 of 11 (permalink) Old 07-22-2009, 05:10 PM Thread Starter
crittergitters.net
woody_1's Avatar
Thanks I will check that out.I have replaced water pump about 5 years ago.I did not see anything coming out the TT weep hole.
woody_1 is offline
post #4 of 11 (permalink) Old 07-22-2009, 05:20 PM
balz out's Avatar
mine showed no signs but when i pulled the pump off the impellar was getting hung up in parts of rotation, changed it and i was back out the next day
balz out is offline
post #5 of 11 (permalink) Old 07-22-2009, 07:07 PM Thread Starter
crittergitters.net
woody_1's Avatar
Great I will try it.I know mine could use a new one.
woody_1 is offline
post #6 of 11 (permalink) Old 07-24-2009, 10:56 PM Thread Starter
crittergitters.net
woody_1's Avatar
Ok I replaced the cap with the same as I had a 16#.When I first started the motor I unscrewed old cap and it had some pressure with a little smoky stuff,but no smell of fuel or oil just antifreeze.Let it run and it did continue to build pressure with same smoky looking stuff???? any ideas??
woody_1 is offline
post #7 of 11 (permalink) Old 07-27-2009, 05:18 PM
MAFIA MEMBER 106
camojeeper's Avatar
oil cooler or head gasket my money on the head gasket
STEVE TDG MAFIA#106
camojeeper is offline
post #8 of 11 (permalink) Old 07-27-2009, 05:46 PM
flintstone's Avatar
Happened to me, check your oil.
1998.5 3500 dually.S300,AIRDOG 150, S&B INTAKE,JUICE W/ATTITUDE, 5" RSD w/ 6" MBRP tip, FLEXALITE, BILLET T.C. H.D. REBUILT TRANS, HAISLEY STUDS & O RINGS, 100 HP STICKS, Hopelessly Addicted [][]==o==[][] #94 Dually Club
flintstone is offline
post #9 of 11 (permalink) Old 08-01-2009, 07:49 AM Thread Starter
crittergitters.net
woody_1's Avatar
OK I am pretty sure it is the head gasket.Is there anything I should do or check or say upgrade (modify while I am doing this? Just a heads up after I finish this and get it back on the street I think it will be for sale or trade.Just time for something new.I have 2 other projects going for other people.(the Wifes-H2 and the oldest kiddo-Yota 4x4).I need something for pulling the boat now.
woody_1 is offline
post #10 of 11 (permalink) Old 08-01-2009, 11:23 AM
flintstone's Avatar
If you are just going to sell it, slap a new head gasket in it, after you sheck the head for warpage. However, if you plan to keep it pick up some head studs and have the head(s) cut for fire rings. I did this on my Cummins and now it should take anything I am going to put to it.
HELP! Truck not running right. firedog90 2008-2010 6.4L Engine Tuner Forum 7 06-28-2009 10:57 PM
Truck is not running right please help!!!!!!!!!! 2tonePSD 1994-2003 7.3L Power Stroke 0 10-21-2007 05:48 PM
Truck still is not running right, HELP!!!! 6point6 2003-2007 6.0L Power Stroke 13 03-15-2006 12:43 AM
I have a Running Truck Again!!!! LokiWolf 2003-2007 6.0L Power Stroke 7 02-05-2006 07:45 PM
Hot running truck sexytrkr 7.3L and 6.9 IDI (Pre 1994) 6 07-22-2005 07:53 PM
