what do you think? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 2tonePSD, this thread has received 3 replies and been viewed 864 times.
post #1 of 4 (permalink) Old 07-22-2009, 05:34 PM Thread Starter
2tonePSD's Avatar
what do you think?
A guy that I no has a 95 f-250 with 161,000 on it. the body has a little rust but that's it. it currently doesn't run. it will crank over but won't fire. and it just so happens that i'm in need of a truck after my little oops. if he got it running he wants 5k for it, but i'm gonna take it not running since i have a Whole motor that i can use if need be. i'm gonna offer 3k for what do you think? o and it has a built trans in it.
RIP.......
96 F-350 Regular cab: 5" to 6" exhaust. autometer Z series a pillar pod for gauges. Window tint.
2tonePSD is offline
post #2 of 4 (permalink) Old 07-22-2009, 06:12 PM
balz out's Avatar
sounds like a perfect spare motor to start and build for the future!!! good luck
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
post #3 of 4 (permalink) Old 07-22-2009, 06:32 PM
4cstr's Avatar
Images: 35
3k sounds like a good starting point.
And it could just be batteries. They provide enough umph to turn the motor over...but not enough is left for the computer to fire the injectors.
Get it for 3k...then put new batteries in it and see if she fires up.
~Dave~
4cstr is offline
post #4 of 4 (permalink) Old 07-22-2009, 11:16 PM
MAFIA MEMBER 106
camojeeper's Avatar
yep get it and use your 96 motor in it more options for big oil and such
STEVE TDG MAFIA#106
camojeeper is offline
