CCV Reroute - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TowRig, this thread has received 9 replies and been viewed 2298 times.
post #1 of 10 (permalink) Old 07-23-2009, 07:54 PM Thread Starter
Send a message via AIM to TowRig
CCV Reroute
How much does your CCv reroute "smoke", mine after thet ruck is up to running temperature "smokes' or "mists" a good amount. I didn't know if this is common it smoking so much or if I just need an oil change?
AJ
2000 F-250 PSD Extended Cab Short Bed
-AutoMeter Gauges;Pyro, Tranny, Boost, Rear Diff, Fuel Pres, Air Pres.
-MBRP Turbo back, muffler delete
-AFE Stage II
-ITP Oil HPX Line
-CCV Mod
-AIH Delete
Trail rig: 1990 Jeep Cherokee, 4.0 I6, NP231 w/ SYE, Clayton Off road Long arm Suspension with coil conversion in rear, Full width Dana 44 up front(ARB, Warn Hubs and US Alloys Chromoly Axle shafts), full width Dana 60 in rear with Spool. 4.88 Gears all around, 36 inch Interco Bias Irok's, and lots of trail damage. :
TowRig is offline
post #2 of 10 (permalink) Old 07-23-2009, 08:00 PM
4cstr's Avatar
Images: 35
Mine does it a healthy amount. I'm not too concerned about it though.
~Dave~
4cstr is offline
post #3 of 10 (permalink) Old 07-23-2009, 08:54 PM
Most will show a decent amount of visible smoke. The amount of smoke depends on quite a few factors, such as outside temperature and humidity, type or brand of oil used, engine temps, and the overall health of the motor itself.
If you are ever worried about the amount of CCV gasses, just perform this simple test. Pop off the oil fill cap, flip it upside down, and set it on top of the oil fill tube. If the crankcase gasses blow the lid off, then you have too much blowby.
Pocket is offline
The Following User Says Thank You to Pocket For this addition to TDG:
4cstr (07-24-2009)
post #4 of 10 (permalink) Old 07-24-2009, 03:52 AM
what is a CCV Reroute?
cong is offline
post #5 of 10 (permalink) Old 07-24-2009, 04:25 AM
plainredtruck's Avatar
Images: 11
Crank Case Ventilation get's re-routed either to a filter or to atmosphere instead of into the intake.
Has the effect of keeping your intercooler cleaner instead of pumping blowby into the intake and your IC.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #6 of 10 (permalink) Old 07-24-2009, 01:22 PM Thread Starter
Thanks for the feedback guys!
-AFE Stage II
-ITP Oil HPX Line
-CCV Mod
-AIH Delete
TowRig is offline
post #7 of 10 (permalink) Old 07-25-2009, 03:32 PM
CrowsSynthetics's Avatar
Send a message via Yahoo to CrowsSynthetics
Post
My CCV smokes quite a bit and stinks. That is why I did this. Here are more pictures.
Bill
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
Amsoil 3000 5w 30 ,Amsoil EaAU Air Filter ,Amsoil Pre filter-EaPF13,
Amsoil Dual Remote By-pass BMK-16A, Amsoil ATF & Transfer case, Amsoil 75w-140 fluid front & rear end, Amsoil Antifreeze Fluid
Edge with Attitude, 4" Turbo Back Exhaust,
5" SS Tip
, Transmission Magnefine filter, Sportman Tonneau Cover & Bush Fender Flairs
Now in the stable a new Black 2009 Jetta Sedan TDI
CrowsSynthetics is offline
post #8 of 10 (permalink) Old 07-27-2009, 10:07 PM
Cratos's Avatar
are you getting any blow back to the CC with that set-up ?? I just used 3/4 inch HH and ran it out the the back.
Cratos is offline
post #9 of 10 (permalink) Old 07-27-2009, 10:17 PM
No and I did a PSI check while runing and romping on it.
Bill
5" SS Tip
post #10 of 10 (permalink) Old 07-27-2009, 11:21 PM
TurboTPI's Avatar
I did the same thing to mt CCV reroute. I put a one way air pump valve off of a ford 302 on it just incase. My truck actually seems to run better with it getting sucked into the exhaust. I've heard that a slight vacuum in the crankcase is better.
92 Firebird Formula 350-Custom turbo setup, 570rwhp, [email protected](daily driver when its nice out)
97 F-250, 4wd, CC, SB, aFe 4in Turbo Back, diy Tymar intake, Edge Evo, CCV Mod, FPR Mod, 1.0 housing, 7.3 SD Cooler
93 Jeep Wrangler 4.0-Up 7in on 36in SS TSL's
09 Polaris Dragon 800SP
TurboTPI is offline
CCV reroute PowerItUp 2003-2007 6.0L Power Stroke 5 01-21-2009 03:28 PM
CCV reroute snoboy 2003-2007 6.0L Power Stroke 16 11-14-2007 05:02 AM
Reroute pcv ? scotts Duramax 2006-2007(LBZ & LLY) 1 10-28-2007 02:26 AM
CCV Reroute utlonghorns416 2003-2007 6.0L Power Stroke 8 09-17-2007 02:38 AM
Ccv Reroute? Wildcat 2003-2007 6.0L Power Stroke 2 01-11-2006 02:37 AM
