DIY intake and noise - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JoeDirte, this thread has received 10 replies and been viewed 2064 times.
post #1 of 11 (permalink) Old 07-26-2009, 10:59 PM Thread Starter
So, I finally did the DIY intake with 6637 and a small length of 4" SS exh pipe on my 2000. I've read up on the things you guys did, but without cutting up the lower half of the battery/air box, the filter doesn't fit in that space very well. I didn't have time to cut anything because I was anxious to do my road trip through the Sierras. The hood squishes down on a small section of the 6637 closest to the fender. At least I know it's wedged in there and thank God the filter has that wire caging. The filter can't go further down under the hood because my air box has a "channel" that sticks up about an inch.
I also read about the louder noise after doing the install. My concern is I heard the louder noise as I accelerated. I sounds like a hiss that get's higher in pitch as I accelerated. A few times as I did this, that gradual louder growing hiss started to become intermittent. Kind of like a locomotive. I backed off the go pedal and it went away. Next time, I'll look at my boost guage to see if that is going crazy. Is this intermittent noise normal?
JoeDirte is offline
post #2 of 11 (permalink) Old 07-26-2009, 11:33 PM
balz out's Avatar
thats your intake sucking in air. i didnt cut anything on mine and i have a 2000 also, it lays right behind the battery perfectly. and i left the battery cover on and all.
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
post #3 of 11 (permalink) Old 07-27-2009, 12:23 AM
Another day in paradise
nevrknow's Avatar
it's doing fine Joe. Your just not used to it because it's "wide" open now. I use the same filters on some of my heavy equipment, and they cost WAYYYY more then our trucks do. Your fine.
2002 f250 4x4 SRW, 7.3L Auto, 4" exhaust, 20" rims on Toyo MT's, Boost, Pyro, Tranny ISSPRO ev's underdash pod., DP TUNER F5, stock, 60 tow, 80 , 120 race, DYI Tymar Intake
2000 New Holland 3930 Diesel tractor
nevrknow is offline
post #4 of 11 (permalink) Old 07-27-2009, 12:50 AM
balz out's Avatar
do yourself a favor and go to magicsmokeperformance.com and get a filter cover....looks cool and gives you a longer life in your 6637
balz out is offline
The Following User Says Thank You to balz out For this addition to TDG:
camojeeper (07-27-2009)
post #5 of 11 (permalink) Old 07-27-2009, 03:00 AM
MAFIA MEMBER 106
camojeeper's Avatar
joe youmay now be getting a bit of turbo surge it is fairly common in our trucks and can be fixed with some cheap and some not so cheap parts the wicked wheel is the cheapest route to stop the surge or ITP diesel has a ported compresser housing for like 3-400 bucks pm me if ya neeed help
STEVE TDG MAFIA#106
camojeeper is offline
post #6 of 11 (permalink) Old 07-27-2009, 08:08 AM Thread Starter
Dang it! This diesel stuff is addictive. I just wanted to get a bit of performance out of it. I don't want to drop $400. I keep telling myself, no more mods.
JoeDirte is offline
post #7 of 11 (permalink) Old 07-27-2009, 06:39 PM
pontiacross's Avatar
that what I said 3 years ago when I bought a set of stage 2 injectors
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #8 of 11 (permalink) Old 07-27-2009, 11:56 PM Thread Starter
Crap. Going to work, I accelerated and got that intermittent sound again. It's most likely surge. I backed off and the sound went away. From what I've read, the ported compressor housing is the way to go. The WW isn't a 100% fix for turbo surge and it takes a lot more work to change out. I don't feel like doing that and end up buying the ported housing. Then I read about the combination of noise from the WW and the ported housing is really loud. I don't need all that noise and the $ and time put in to the swap.
2000 F250 Supercab 2wd, 6spd, DP Tuner, Southbend conFE, MBRP 4" turbo back straight pipe. DIY intake.
JoeDirte is offline
post #9 of 11 (permalink) Old 07-28-2009, 12:10 AM
MAFIA MEMBER 106
camojeeper's Avatar
the WW killed my surge even with hybrids
STEVE TDG MAFIA#106
post #10 of 11 (permalink) Old 07-28-2009, 02:25 AM
balz out's Avatar
anyone i ever talked to says that ww kills all surge and gives your better performance, compared to stock super duty turbos
balz out is offline
S&B intake noise question.....What is this?? jdeere5105 1994-2003 7.3L Power Stroke 8 07-03-2009 01:32 PM
odd noise edged dodge 5.9L Cummins (1998.5-2002) 4 03-14-2008 01:25 PM
added a K&N intake system weird noise now zippar 1994-2003 7.3L Power Stroke 6 01-20-2007 07:59 PM
Odd Intake Noise Notorious6.0 2003-2007 6.0L Power Stroke 4 11-29-2006 07:42 PM
Got noise ? Unbroken The Parking Lot 8 11-07-2005 06:03 PM
