wicked wheel - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ryanss22, this thread has received 15 replies and been viewed 1806 times.
post #1 of 16 (permalink) Old 07-27-2009, 12:10 AM Thread Starter
wicked wheel
has any one tried the wicked wheel? or any other compressor wheel's? any noticeable difference? any plus's or minuses?? also can anyone tell me what type of turbo a 1996 f250 has? also if I go with a rosewood DIY kit for my 1996 would the stock 15* hpop be good? or should I step up to a 17* , ?
ryanss22 is offline
post #2 of 16 (permalink) Old 07-27-2009, 01:42 AM
dzljon's Avatar
the wicked wheel is the same compressor wheel that is already in the obs trucks (pre superduty) so you wont gain anything Which DIY kit are you referring too? I am assuming you have an OBS truck so if you go with 165cc sticks you should be fine with good tuning but as aways if you give the injectors more oil they will be happier. IMO save you rpennies and get a bigoil system of your choice they are all good I only have personal experince with stealth.
99.5 F250, VGT 5.9 CR cummins
dzljon is offline
post #3 of 16 (permalink) Old 07-27-2009, 03:02 AM
MAFIA MEMBER 106
camojeeper's Avatar
terminator engineering oil systems
STEVE TDG MAFIA#106
camojeeper is offline
post #4 of 16 (permalink) Old 07-27-2009, 10:12 PM Thread Starter
just the stage 1 inj. nothing to crazy. would I notice any improvment if I kept the stock hpop?
ryanss22 is offline
post #5 of 16 (permalink) Old 07-28-2009, 12:27 AM
dzljon's Avatar
you will most likely see some improvment, but you will also see alot more black smoke also, this is also pending the condition of your stock pump.
dzljon is offline
post #6 of 16 (permalink) Old 07-29-2009, 12:30 AM
pontiacross's Avatar
not trying to takeover this thread but, I still have the old stock turbo laying around off of my truck. I have a friend that hauls my truck to all the pulls with his O1, and his turbo surges horribly. can I pull the intake weel off of my old turbo and put it into his superduty turbo?????
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #7 of 16 (permalink) Old 07-29-2009, 01:18 AM
balz out's Avatar
if your talking about stage one diy injectors, i thaught they are stock rebuild kits?
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
post #8 of 16 (permalink) Old 07-29-2009, 01:27 AM
Riding solow on the Hog
Sleeperstroke's Avatar
Yes.
"MOby" The big white bio-burning 03 7.3 4x4. 6637, straight piped stock exhaust, and a new "secret" blend of Haul asBLEEPsing mods and upgrades. Suffice to say, its still not the fastest, but its quick enough to worry lots!
Sleeperstroke is offline
post #9 of 16 (permalink) Old 07-29-2009, 01:47 AM Thread Starter
yes I am talking about the rosewood DIY stage 1 kit, I am asking becouse it basically doubles the amount of fuel my injectors can flow (stock 90 - DIY- 160)
ryanss22 is offline
post #10 of 16 (permalink) Old 07-29-2009, 02:34 AM
CSIPSD's Avatar
You will be fine with the 160's, if you can get your hands on a 17* pump then do it, but you will not "need" it.
CSIPSD is offline
wicked wheel? 7inchstack 1994-2003 7.3L Power Stroke 10 04-28-2009 09:10 PM
wicked wheel King0581 1994-2003 7.3L Power Stroke 9 03-11-2008 03:35 AM
wicked wheel platinum01 Supporting Vendors Forum 2 10-10-2007 04:31 AM
Wicked Wheel? jjmachine 1994-2003 7.3L Power Stroke 5 08-29-2007 02:36 AM
Wicked Wheel PSmokinD General Ford Truck and Excursion 15 03-09-2006 12:29 AM
