94-97 performance upgrade with 99-03 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ryanss22, this thread has received 8 replies and been viewed 1973 times.
post #1 of 9 (permalink) Old 07-28-2009, 01:56 AM Thread Starter
is there any stock parts from a 99-03 that can be put on a 94.5-97? such as turbo (so it has an adj. wastegate) or any other parts? my buddy just wrecked his 01 7.3 and said I can have any parts I want. I have a 96 7.3 by the way
ryanss22 is offline
post #2 of 9 (permalink) Old 07-28-2009, 02:03 AM
4cstr's Avatar
Images: 35
grab his hpop at the least.
~Dave~
4cstr is offline
post #3 of 9 (permalink) Old 07-28-2009, 02:44 AM
Intake plenums, uppipes, collector, turbo pedistal, turbo...
There will be some fab work involved to make the downpipe fit (more so than making any other OBS downpipe fit), but it's not too bad.
jvencius is offline
post #4 of 9 (permalink) Old 07-28-2009, 06:47 PM
joebob3093's Avatar
Send a message via Yahoo to joebob3093
and get the HPOP
{95 F250 Powerstroke XLT} 5 spd, Wildman 6 pos. chip, custom IC, ADs, AFE stage 2 intake, 3" down pipe to custom 5in stack. EBPV break, shimed FPR, idm mod by mattymx, CCV mod, Leveling Kit, diprocol egt and boost guages.
joebob3093 is offline
post #5 of 9 (permalink) Old 07-28-2009, 09:34 PM Thread Starter
so your saying the turbo will bolt up? is this a major upgrade over my obs style?
ryanss22 is offline
post #6 of 9 (permalink) Old 07-28-2009, 10:04 PM
Resident GINGER
CFRO's Avatar
Send a message via MSN to CFRO
Not quite. That is why you need to get the up pipes, pedestal, and all the other stuff. but if you upgrade to these, then you will be able to swap over to a larger amount of turbo's down the road, where the OBS style hardly has any drop in turbo's.
08 Ranger Grabber Orange. XLT 4x4 5 Speed Manual Super cab. Sirius. Silvana 9007 and 9415's. Amsoil 0w30 (Mileage Maximizer). Dee Zee Powder Coated Tool Box (PEELING). Dual 3' Fire Sticks. Cobra 75 X.
94 F-350 CC LB 5 -Speed. 4.10's. MBRP. Single Mass. 265/75's on 16x8's. Uniden CB. 3' Firestick.
Single club # 61
CFRO is offline
post #7 of 9 (permalink) Old 07-29-2009, 12:26 AM
pontiacross's Avatar
get the intercooler. I dont really considder the turbo an upgrade, but I would latch onto the exhaust manifolds, uppipes and pedistale incase you want to go to a 38r turbo in the future.
the injectors would be a slight upgrade but you would need special programming and the HPOP to run them.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #8 of 9 (permalink) Old 07-29-2009, 12:58 AM
CSIPSD's Avatar
Get his HPOP and injectors... Leave the rest...
The turbo is NO upgrade, the only thing you will get with his turbo is surge. His injectors are almost 40% more fuel then you have now, assuming you have AA injectors (90CC) and the 01 has AD's (140cc). With the bigger injectors and the 1.15 housing your stock turbo has, its like a match made in heaven. If you can get his intercooler, that would be nice too, but will require some work to add it.
CSIPSD is offline
post #9 of 9 (permalink) Old 07-29-2009, 12:59 AM
CSIPSD's Avatar
Its not perfect, but you can run the AD's on single shot programing. Its not like running singles on split programing...
CSIPSD is offline
00 250 what should i upgrade first? prolxstang89 1994-2003 7.3L Chips & Tuners Forum 2 04-15-2008 04:54 AM
looking for the 7.3 A/C upgrade Paul Ray Supporting Vendors Forum 1 02-11-2008 08:22 PM
maybe upgrade the outside? Bcarriveau General Ford Truck and Excursion 4 11-04-2007 04:53 PM
first upgrade 199eightcummins 5.9L Cummins (1998.5-2002) 20 05-07-2007 02:38 PM
performance upgrade bully 1994-2003 7.3L Chips & Tuners Forum 10 06-02-2006 08:08 PM
