Slip Yoke Grease??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Stroker01, this thread has received 1 replies and been viewed 2745 times.
post #1 of 2 (permalink) Old 07-28-2009, 04:10 AM Thread Starter
Stroke 'em!!!
Stroker01's Avatar
Slip Yoke Grease???
I am in need of greasing my slip yoke on my truck because it is clunking when I take off. So I am wondering what is the part number for me to buy the grease from the dealer. Also I would like a quick refresher on how to approach greasing the slip yoke.
Thanks
2001 F-250 7.3L, 2wd SRW, Straight Piped with a 25in long Black 6in Tip, Semi Air horn, CCV mod, Zoodad mod, Foil Delete, DIY Intake, Ravelco Anti-Theft Device, issopro gauges.
See videos of my truck at http://www.youtube.com/DieselStroker01
Stroker01 is offline
post #2 of 2 (permalink) Old 07-28-2009, 11:38 PM
swampratxxx's Avatar
The grease I use is GM part #12345718. It's compatible with rubber.
I remove the driveshaft from my truck so it's easier to do. You can spread
the factory clamps apart just enough to get the boot off. Index both ends
so it goes back together same as before. take apart and clean old grease
out. Coat splines with new grease and work it in and out. Reinstall halves
together with boot and resecure clamps with clamp pliers(or very carefully
with side cutters but don't over do it).
2001 Ford F250 4x4 CC SB 7.3l AT
Hicap Air Filter w/ Zoodad Mod
100,000 miles
"I can explain it to you, but I can't understand for you."
swampratxxx is offline
Powertrax NO-SLIP locker/Limited slip tony597fitter Dodge Parts 1 07-09-2009 04:22 AM
Powertrax NO-SLIP locker/Limited slip tony597fitter Ford Parts 0 07-06-2009 06:23 AM
yoke bearing 8yourv8 General Ford Truck and Excursion 0 06-04-2009 12:12 AM
pinion yoke imported_diesel71 2003-2007 6.0L Power Stroke 0 04-08-2006 02:37 AM
Dana 80 yoke House Whats Been Sold 0 01-05-2006 06:17 AM
