engine stalling problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kilalove21, this thread has received 7 replies and been viewed 1712 times.
post #1 of 8 (permalink) Old 07-28-2009, 06:56 PM Thread Starter
2000 f550 7.3l
when i coast in gear and then brake my truck rpm's drop and sometimes stall. when i go right to braking, the rpm's stay normal.
would this be a pcm issue? fuel pump?
thanks for your help.
kilalove21 is offline
post #2 of 8 (permalink) Old 07-28-2009, 08:42 PM Thread Starter
koeo - no codes
koer - p0476 exhaust pressure control valve
contribution test - #3 p0269 + #8 p0284 cylinder balance fault
injector buzz test - no faults
rpm - 660
baro - 29
4.6v
81Hz
exhbp - 14psi
.9v
eot - 178f
1.39v
fuelpw - 2.85ms
iat - 2.59v
84f
icp - .8v
injcontprs - 485psi
injprs - 7%
map - 14psi
mfdes - 9mg
sccs - 6.84v
vfdes - 11^3
here are the specs on the truck as it is idling. all were pulled with a solus pro. hope this will help someone help me with my problem in the previous post.
post #3 of 8 (permalink) Old 07-31-2009, 05:45 PM
can you tell how low your icp gets when it does stall? my '94 was doing the same thing awhile back due to a torn upper injector o-ring and I was losing all my high pressure oil. could also be an ipr valve not working right. mine would be driving fine until i pushed the clutch in and then it would die as soon as i did. looking at your stats there, your icp does seem a little low. once i got mine running right again, i had about 1000 psi at idle. i checked that with a manual gauge though.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. BDP modded IDM. Heim joint clutch linkage. Adrenaline HPOP. LUK SMFW. DIY Elec. Fuel. FS1282, FF5230 fuel filters.
sdan27 is offline
post #4 of 8 (permalink) Old 07-31-2009, 06:58 PM Thread Starter
i took it to the dealership and they tried to update the pcm but it kept kicking their computer out, i have a new pcm on order and should be in later today or monday morning. i'll post if there is any change.
post #5 of 8 (permalink) Old 08-10-2009, 03:26 PM Thread Starter
well, with new pcm, ipr, hpop, hpos, it still has a drop in rpm the way it did before. it runs fine and has a little more power than before and when you go directly from the accelerator to pressing the clutch and braking it idles down fine. the problem is when you coast with the trans engaged and then clutch/brake the rpms drop and the truck wants to stall.
i'm out of ideas and this truck is starting to work a nerve so any help is appreciated.
post #6 of 8 (permalink) Old 08-10-2009, 03:30 PM
Could you have a sticky mechanism in the clutch linkage that's not letting the clutch fully disengage and consequently killing the engine? It's a bit of a stretch, I know, but you've already ruled out the first line of stuff I'd look at...
jvencius is offline
post #7 of 8 (permalink) Old 08-12-2009, 05:19 PM
MAFIA MEMBER 106
camojeeper's Avatar
can you data log it and post the results? were way past the easy stuff
STEVE TDG MAFIA#106
camojeeper is offline
post #8 of 8 (permalink) Old 08-12-2009, 06:46 PM Thread Starter
i'm not quite sure how to, are you refering to the solus?
2001 International 4700 Bucket T444 engine ignition problem Braelecorp Medium and Heavy Duty 1 05-23-2009 05:34 AM
Engine Problem. Maybe Injector? mrit 1994-2003 7.3L Power Stroke 0 04-12-2009 09:43 PM
help engine problem 7.3ford350 1994-2003 7.3L Power Stroke 5 08-06-2007 05:33 AM
engine code problem bigboy6.5 6.5L Diesel Engine 9 02-18-2007 04:34 PM
check engine light problem....again Youngone00 5.9L Cummins (1998.5-2002) 3 01-06-2007 06:17 PM
