grinding noise - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cong, this thread has received 4 replies and been viewed 1162 times.
post #1 of 5 (permalink) Old 07-31-2009, 03:58 AM Thread Starter
grinding noise
2000 f250 when im driving down the road its fine but when I start to slow down just a litter, It starts making a grinding noise. this doze not happen cruising around, just on the high way. going down a hill and just costing with alitter bit of gas u can really fill it. if you let all the way off the gas it go's away, it like a sweet spot
cong is offline
post #2 of 5 (permalink) Old 08-02-2009, 05:06 AM Thread Starter
i has 18" on it too if that means anything. I was thinking u-joints
cong is offline
post #3 of 5 (permalink) Old 08-02-2009, 05:21 AM
********* and Mafia #90
Bcarriveau's Avatar
could be a u-joint.. Best thing you can do it get all 4 off the ground and go over the truck..
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #4 of 5 (permalink) Old 08-02-2009, 05:52 AM
Bruno2's Avatar
Next time you are coming home from work and hear the noise either wait till you get home or pull over and put your hand on the ujoints . They shouldnt be hot , so if they are then they are starved for grease or its just their time .
7.3 psd ,Z-F5 , ARP headstuds , ARP main studs , D-66 dominator Turbo ,EBPV delete pedestal , MBRP 4" straight pipe , Rosewood stg II's , Tony's tunes 6 pos, K&N gen II intake ,comp 910 springs , Hurst line lock . Ford IC, Banks piping kit .
Alpine deck
Rockford Fosgate subs
Rockfod Fosgate amp
4 Pioneer 5x7
Clarion amp
HD leaf springs ,Over sized drive shafts , heavy duty precision u-joints all the way around
B.O.M.B. squad member #39
Singles Club member #251
Walnutter #8
Bruno2 is offline
post #5 of 5 (permalink) Old 08-02-2009, 06:17 AM
Dually Club #3
jdydiesel's Avatar
Lift each wheel off the ground and spin the tire, you might have a bearing going out.
Jason
72 F-250 Gasser.FOR SALE
jdydiesel is offline
4wd grinding noise Cummins_1984 5.9L Cummins (2003-2007.5) 8 05-11-2009 04:10 PM
loud grinding noise Nick Albert 5.9L Cummins 12 Valve (1994-1998.5) 6 03-11-2009 12:08 AM
What is that grinding noise?!?!? PSDlover 1994-2003 7.3L Power Stroke 2 02-18-2008 05:59 AM
Vibration/Grinding Noise after installing 6" superlift SanRafaelDiesel General Ford Truck and Excursion 5 06-02-2007 05:49 PM
Rattle/Grinding Noise comming from TC Vinni General Ford Truck and Excursion 2 03-15-2006 04:45 AM
